Old 11-11-2025, 02:07 PM   #1
1971bluec10
engine/ trans mount questions
im looking at the Dirty Dingo sliders which i know have been around a while but what 4l60e crossmember being used with these?
also looking at the tinworks kit with everything but dont see anything really on here talked about them..
any opinions on these?
thank you
1971bluec10 is offline   Reply With Quote
Old 11-21-2025, 02:15 PM   #2
bigmoe
bigmoe's Avatar
Re: engine/ trans mount questions
There are a lot of aftermarket options for you. I found this unbranded one on Ebay that is adjustable at every point and has the dip up clearance for exhaust.
https://www.ebay.com/itm/38902074177...3ABFBMtJ7t-NRm
bigmoe is offline   Reply With Quote
Old 11-23-2025, 02:19 PM   #3
leegreen
I've had poor luck with the poly bushing inside of a pipe style of mount. The bushings fail quickly. Look for factory rubber style mounts. Chances are the aftermarket mounts share geometry with an OEM mount
leegreen is offline   Reply With Quote
Old 11-24-2025, 11:08 AM   #4
truckdude239
truckdude239's Avatar
i used drity dingo sliders with tht stock gm 350 transmission mount/crossmember i just had to redrill the holes in the frame, and move the crossmemeber backwards
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 11-24-2025, 12:11 PM   #5
Rich84
Rich84's Avatar
Same here on both my swaps..
Rich84 is online now   Reply With Quote
Old 11-25-2025, 02:06 PM   #6
1971bluec10
awesome thank you all for the help
Old 11-25-2025, 08:34 PM   #7
TrybalRage
I used Tejas motor mounts, and like everyone else just reused the stock transmission mount. Tejas does make a nice trans mount as well, or if you were looking for a budget option I've had this in my amazon wishlist forever. https://www.amazon.com/dp/B0BLBLFGLF/
1985 C10 Silverado LWB LS Swapped! Other Stuff
2010 Suburban 2500 LT 4WD
YouTube
TrybalRage is offline   Reply With Quote
Old 11-27-2025, 04:16 PM   #8
WorldsCrappiestTruck
I’ve used that mount twice - one had the mounting tab for the trans mount adjustable, and one had it welded in place so you couldn’t fine-tune driveline angle.
Either works. They feel fairly cheap & Chinsy but certainly do the job (and give room to run the exhaust.
WorldsCrappiestTruck is offline   Reply With Quote
