#326 |
Re: Project "Financial Burden": 1968 SWB C10
wow. Nice job. I think the microfiber towel I use to wash my truck is rougher than 8000 grit.
#327 | |
![]() Join Date: Apr 2005
Yep, I couldn't help myself. I had to give it a try.
You're probably right! That 8000 paper is really neat; it even has an integral foam interface pad. That system was designed for the collision industry to reduce the amount of time spent buffing. It only took a few quick passes with the polish. I really like that.
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675 2011 Dodge Ram 1500 2012 Camaro ZL1 |
#328 |
![]() Join Date: Jun 2002
Could you give some details on the paint booth you built? I hope to do something similar when the time comes.
Thanks, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#329 | |
To join all the tubing I used safety railing fittings like this. https://www.globalindustrial.com/c/s...PG-78243-42979 The only drawback is that 1" conduit has a smaller outside diameter compared to 1" pipe. So I made some press-on aluminum sleeves to upsize the end of the conduit to work with these fittings. For the plastic wrap I use this for the roof. https://www.amazon.com/3M-06723-400-...75&sr=1-1&th=1 and this for the sides. https://www.amazon.com/Scotch-Painte...75&sr=1-5&th=1 I splurged a bit and decided to use proper paint booth flooring from Pigmat. I use a vacuum to clean it up after each use. It's really helped keep the debris down inside the booth and it keeps you from tracking dust in and out. https://www.amazon.com/New-Pig-Absor...1zcF9hdGY&th=1 I just use 4 garage fans to push air into the booth through standard paint booth intake filters. This keeps the booth pressurized so dust and dirt can't enter. https://www.amazon.com/wioboy-Paint-...%2C127&sr=8-17 and then I built a frame holder to allow air to exit through standard 20"x20" paint booth filters. https://www.amazon.com/wioboy-Exhaus...1zcF9hdGY&th=1 Lastly a zipper allows for easy entry and exit through one of the walls. https://www.amazon.com/gp/aw/d/B0022...9-f263eebf9e13 It's not a super cheap budget setup, but it's really helped improve my paint quality and it keeps all the overspray contained very well.
#330 |
The weather cooled off a bit this weekend. I was able to get the fenders knocked out. Two more steps closer...
#331 |
The results are impressive. Paint is laying down very well from my vantage point. Won’t be long and you can final assemble all those beautiful parts.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
#332 |
Thanks for the list on the paint booth. I can tell it is helping by the finish of your parts.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 08-04-2025 at 09:49 PM. |
#333 | ||
I finished up the cowl panel and grill. I'm staying true to the 68 model year with the non-body colored grill, but changing it up a bit from the typical white grill you mostly see with this color. If you've followed along you've already seen I've done the same black treatment on the bumpers and other external parts. The grill is just a little flatter finish than the semi-gloss/satin I've used elsewhere.
#334 |
I decided to knock out the bed floor given the way I have the parts stored. It just needed a little body work around my gas tank filler; otherwise just scuff and shoot. It kind of feels like cheating to have a bed floor this flat with so little effort, glad they make a good reproduction. Now I have to flip it over to Raptor line the bottom side.
#335 |
Wow, impressive.
#336 |
Looks great. Better than off the assembly line for sure. Are you starting out with 2 tack coats of paint and then 2 wet coats? It’s laying really smooth.
#337 |
Thanks! The first coat of clear I move just a little faster than normal, but everything else I keep the same regardless if its sealer, base coat or clear. I also don't sweat about full coverage or really making it look shiny. I just want a nice sticky base for the next two coats. The second coat I go a little slower than the first and keep the gun distance close to the panel (4-5 inches for my gun). The final coat I do just like the second, but I give it a little more flash time before starting to let the solvent escape from that heavier second coat.
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675 2011 Dodge Ram 1500 2012 Camaro ZL1 Last edited by Old_Truck_Fan; 09-14-2025 at 10:12 PM. |
#338 |
I was able to finally finish up the doors today. There is so much work in getting them dialed in including all the seam sealer; I'd recommend 3M 08528. It has just the right amount of "flow", but not so much that it would run off of anything. You can tool it with an acid brush or a small paddle and it will melt in for a nice smooth finish. 3M has some great YouTube videos of best practices. Bed sides are next...
#339 |
Forgot to mention I also finished the bottom of the bed in Raptor liner.
#340 |
Moving right along, and temps/humidity are dropping. I can see you rolling around in this thing before long. Keep at it. Excellent work.
#341 |
You're right, trying to keep moving while the weather is nice. I feel like I'm running a body shop on the weekends, but it's fun. I knocked out both of the bedsides and now I'm tackling the hood. I've been a bit spoiled working with new sheet metal, my hood is going to need a lot of work to get it smooth. I'm guessing it's going to be the hardest panel on the truck.
#342 |
Wow, you're doing an amazing job with the paint. A major milestone for sure
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
#343 |
Going to be beautiful for sure! Your attention to detail is fantastic, right down to the "square peg in a round hole" shifter boot adapter.
#344 |
Hope 2026 is off to a good start for you!! Question on the wiring and your battery location. I didnt see your final battery hookup, but I have purchased the same battery box and trying to plan ahead the best I can. I have purchased the pass through bulkhead connectors to go through the frame: Connectors Also curious where you brought your power in. I see your firewall distribution block, but also one in your glovebox I think. If you care to share any details on that, I would appreciate it. You have done a great job at hiding wires..almost too good.
#345 |
Excellent work on the whole truck. As small of components as they are considering the project, I must say I love the work on the fuel fill and the exhaust reliefs.
The lid is stuck on my jar of anti seize |
#346 | |
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675 2011 Dodge Ram 1500 2012 Camaro ZL1 Last edited by Old_Truck_Fan; 01-12-2026 at 11:43 PM. |
#347 |
#348 |
Thanks geunther for noticing the details. I enjoyed getting creative on both of those aspects.
#349 |
Yessir, thanks for taking the time to write it up. The battery in the back truly does clean up the under hood wiring. Gives a clean look, but all your wiring is easily accessible. I like it. I will have to look up the cable tie mounts. Come on spring!! Plenty of detailed info that I can use as a guide. Again, truly appreciate it.
#350 |
I needed a way to paint my cab floor and decided to make a variation of the typical "tip and flip" cab dolly. I wanted something that I could break down easily and would not take up a bunch of room when stored. I used 1.5" roll cage tubing and associated joints. It bolts to the existing cab mount locations, breaks down in 4 pieces, and I use my engine hoist to flip it over for a one man operation.
| Bookmarks |
