Old 01-05-2026, 08:57 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
What is this part called and where can I get it
What’s it called and where can I get one
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 01-05-2026, 10:57 PM   #2
franken
Re: What is this part called and where can I get it
Was it under the steering wheel? Turn signal cancel cam. Dry the Dorman help section at the parts store.
Old 01-05-2026, 11:25 PM   #3
1970 CST Short Wide
Senior Moment
That’s where it came from but it runs the Horn
Pittsburg Ca
94565
Old 01-05-2026, 11:32 PM   #4
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
It's the horn contacting ring.
https://classicparts.com/1967-72-hor...DLRtdOyBofknrM
~Steven
Simi Valley, CA
Old 01-06-2026, 01:20 AM   #5
1970 CST Short Wide
Senior Moment
Originally Posted by Steeveedee View Post
Thank you Steven.
It’s ordered, I just need to figure out the wire
Steve
Pittsburg Ca
94565
Old 01-06-2026, 01:34 AM   #6
Sheepdip
Sheepdip's Avatar
Originally Posted by 1970 CST Short Wide View Post
Thank you Steven.
Steve
The wire will be the "Grounding Path" to the horn relay.
Sheepdip is offline   Reply With Quote
Old 01-06-2026, 01:53 PM   #7
1970 CST Short Wide
Senior Moment
I get that part. I didn’t see a wire with the new part. My old part has some sort of spring inside the cone where the wire comes out. What ever is there was supposed to make connection to the ring , that contact is Not being made.
When the new part arrives it should be easier to figure out
Thank for the input
Pittsburg Ca
94565
Old 01-06-2026, 08:18 PM   #8
70shortfleet
70shortfleet's Avatar
The one you show in your picture is for a tilt column, hope didn't order the one that was in Steeveedees post, that was for a non tilt column they are different!
70shortfleet is offline   Reply With Quote
Old 01-06-2026, 09:27 PM   #9
1970 CST Short Wide
Senior Moment
Yes I ordered the one that looked exactly like the one I have. It’s for a tilt which is what I have.
Pittsburg Ca
94565
Old 01-06-2026, 09:34 PM   #10
Steeveedee
Steeveedee's Avatar
<wipes sweat off forehead> Glad of that! I really do try to get things right, but I didn't know that he had a tilt.
~Steven
Simi Valley, CA
Old 01-06-2026, 10:40 PM   #11
1970 CST Short Wide
Senior Moment
Don’t sweat it LOL. When I saw that the part mentioned Non Tilt I figured it out
Thanks for the link, I do Appreciate it
Pittsburg Ca
94565
Old 01-07-2026, 09:09 AM   #12
Jason Banks
Jason Banks's Avatar
That wire is something that is added to that part with an aftermarket steering wheel.
Not sure if this is the right one but you can possible look at the instructions for this item:
https://www.summitracing.com/parts/g...ckup/year/1967
Jason Banks is offline   Reply With Quote
Old 01-07-2026, 07:03 PM   #13
Don D
Junior Member
You also going to need the spring. Goes on the shaft first then cancel cam.
Don D is offline   Reply With Quote
Old 01-07-2026, 09:01 PM   #14
1970 CST Short Wide
Senior Moment
Ya I thought there was a spring missing. I was trying to find where to buy one then went out to my “ never throw anything away cubby hole” and found a spring that works perfect just waiting on the new ring
Pittsburg Ca
94565
