Old 01-17-2026, 06:48 PM   #26
r8rs4lf
Re: AC/fan switch
Here is the pic of the plug. You can see the box in the background.
r8rs4lf is offline   Reply With Quote
Old 01-17-2026, 06:56 PM   #27
dmjlambert
dmjlambert's Avatar
Re: AC/fan switch
Originally Posted by r8rs4lf View Post
I just went outside and moved the plug to the CIG position and I got HIGH to work. That's crazy, it just needed power besides (probably a blown fuse in the glove box position) the fact it was plugged in to the wrong place.
I also looked at the plug on the hanging red wire. I slid it onto the stud on the rear of the lighter, but it would not stay. The new red wire has that exact same plug on one end and the other end has the plug to attach to the piggy back.
It's all starting to come together!!
What about the green wire, could I potentially plug that in to the yellow wire attached to the piggy back in my previous pics?
One more thing, I saw a plug just hanging there and this box attached to the firewall that looks like it belongs there. What is that and does that plug belong on it?
Yes, it seems to be coming together for you. I don't know about the wire not staying on the stud, others may chime in with what to do. I don't know about exactly what to do with the green cig lighter light wire, but you probably want it on a switched circuit such as radio or IGN UNFUSED or PNL LTS (which is dimmed through the rheostat on the headlight switch for dash lights.
The box on the firewall that you picture is a relay, and it may or may not be one you need. If your horn is working, then that relay may be for something else such as anti-dieseling relay (which you probably don't need to worry about, it was only on some model years). See what remains not working on your truck before worrying about that relay.
Old 01-17-2026, 07:01 PM   #28
dmjlambert
dmjlambert's Avatar
Re: AC/fan switch
I don't remember that plug shape, but you can figure it out based on the wire colors going into it and looking at the wiring diagram, probably. Here is a wiring diagram, it is not perfect because it tries to cover all model years and the wiring does vary a little from year to year.
http://67-72chevytrucks.com/vboard/s...27#post9186727
The more perfect wiring diagram is in the year specific service manual, which can be found here or you may get a paper copy for reasonably cheap. It may be harder to read than the color diagram.
http://67-72chevytrucks.com/vboard/s....php?p=5781194
Old 01-17-2026, 07:02 PM   #29
r8rs4lf
Re: AC/fan switch
Everything seems to be working now. I'll plug that in to see if the horn starts to work.
I really appreciate your help!
Old 01-17-2026, 07:06 PM   #30
dmjlambert
dmjlambert's Avatar
Re: AC/fan switch
No problem. Be sure to unplug all that stuff before you sell the truck! ;-)
My dad always taught me that if you are going to do something do it right the first time. Obviously this was not the case with whoever just mounted the lighter and not understand the consequence that came with it.
Yes!
Old 01-17-2026, 07:39 PM   #31
r8rs4lf
Re: AC/fan switch
Yes!
Nah I won't be selling this truck!
FYI, I inserted that plug in to that relay and the horn started going off! I checked under the horn on the wheel and it's not hooked up correctly, no wires.
Again, thank you very much for your help. It always feels good to fix things on our own (with the help of other sometimes) and also get to know our own vehicle instead of taking it somewhere to have someone diagnose and fix it while gouging you at the same time.
