Old 01-18-2026, 01:46 PM   #4
IT Cowboy
IT Cowboy's Avatar
Re: Would a new fan and clutch improve my cooling?
I think the temp creeping up is from heat soak. When I am running on the highway it is usually ok but when I come off the highway and down to cruising and stop and go traffic it them tends to go towards the warm side.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
