Old 01-21-2026, 12:56 PM   #21
IT Cowboy
IT Cowboy's Avatar
Re: Would a new fan and clutch improve my cooling?
I ordered a clutch and 7 blade fan to install. It looks like a pretty straight forward job - unbolt and bolt in. Will the old fan and the new one slip in without removing the shroud?
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
