Old member
Thanks, I'm going to start buying up parts for it starting next week after all the winter storm moves out. I have a chassis already built pretty much. I may end up having to redo the front end though. I built it for another roadster body but when I found Jay and his company I just decided to use it. The front wheel base is gonna be to narrow I think for the truck but it want take much work to widen it.
It has a set of Miata & Jakes Hydraulic disc brakes. The Miata are a kit for golfcarts I have made to work on the back axles of EZGO or CLUB CAR rear ends. I use a Wilwood Disc Brakes 14-0008: Summit Racing Master Cylinder and Pedal Pro Packs for the ease of installing.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
| Bookmarks |
