Gas leak?
Took the 72 out for a spin, got groceries and filled it up.
Stopped for like 5 minutes (not running) to get matching vintage cooler and there was a gas puddle on the passenger side by rear wheel. The truck was parked at an angle ( passenger side slightly lower). I came home and it isn’t leaking now? Any suggestions? |
#2 | |
The Older Generation
Re: Gas leak?
That's a strange one. Possibly leaking around the sending unit hole or the return line on the tank? Was there a strong smell of gas in the cab?
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-05-2026 at 10:32 PM. |
#3 | |
Re: Gas leak?
No smell of gas in the cab at all, can smell it outside a little where it leaked but I don’t see anything. |
![]() Join Date: Dec 1999
Re: Gas leak?
Filler neck connector hose original? 50+ years takes its toll. You mentioned a fill up. Could have leaked onto top of tank and dripped to passenger side. Still running a sealed (not vented) cap?
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Re: Gas leak?
I have to crawl under and take a look. Yes running a regular non vented cap.
Re: Gas leak?
On my 67 Burban there is a hidden piece of fuel hose on the passenger side near the 3rd door pillar in front of the trailing arm crossmember. It is a 5-6" U-shaped hose that connects the steel in from the fuel pump to the steel line that goes to the fuel tank. I don't know if it is that way on all 67-72 Burbans of only 67's.
I cut the 90 degree bends off and replaced mine with compression fittings and a piece of steel line. Circled in photo.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#7 | |
Re: Gas leak?
If you find another leak, it may be good to clean this hose and check it for cracks or just replace it anyways. Good Luck. |
| Bookmarks |
