Old 02-10-2026, 05:05 AM   #1
Ziegelsteinfaust
Helper air bags placement
I am heavily leaning into the idea of lowering my truck more when I replace the motor I wounded, but my helper air bags will not to keen on the idea.
They are placed outboard above the axle to provide maximum stability, and unfortunately the set up can not be dropped any more.
So which option do you guys like the best when towing or hauling stuff around.
Move the bags in board on the frame and use drop mounts to get suspension travel
Or
Move the air bags over the leaf springs and have them staggered opposite of the shocks?
Ziegelsteinfaust is offline   Reply With Quote
Old 02-10-2026, 09:05 AM   #2
hewittca
hewittca's Avatar
Re: Helper air bags placement
What spring/shock setup do you have currently, and how much lower are you wanting to go? I ran 4" HD drop springs and 2" blocks in the rear, which got me as low as you could go without needing a C-notch. The 4" HD springs were intentional because I still wanted to haul things occasionally. I mention this option because maybe you don't even need the helper bags if you go HD springs. I was able to load the bed to its max rated capacity with no problems.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 | Oscar the 70 C10
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 02-10-2026, 05:55 PM   #3
Ziegelsteinfaust
I have took about 2/3rds out of a C20 65" pack to make my rear springs.To which I added a axle flip, and flipped the rear shackle. Combined with drop axle mounts for the shocks.
Its rides quite nice and sporty, and handles a few hundred pounds very well. Just when I get a engine or 2 in back. It needs the bags for sure.
Old 02-11-2026, 10:53 AM   #4
SCOTI
SCOTI's Avatar
If the springs & shocks work fine as-is unloaded, locate the bags where they fit. If putting them inboard gets it done & is easiest, then that works. If not, the staggered arrangement would work too.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
