Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 03-04-2026, 01:59 AM   #26
57taskforce
All about them K’s
57taskforce's Avatar
Re: I am seeing videos about Chevy and Fords
TCM tuning makes a huge difference in how the late model automatics shift, both in speed and firmness as well as shift points. At wide open throttle, the tune in the 6l80 will cause my Camaro to jump sideways with the traction control on in the 1-2 shift and then will bark them in the 2-3 and 3-4 shifts. At light throttle is shifts just as smooth as the stock tune. It takes about 1/4 throttle to command any given down shift. A wide open throttle down shift in lower gears will spin the tires if you aren’t on top of pedal management. This is all on the stock ~400 hp ~410 tq 6.2. I tuned it myself and it is a blast to drive. You can clean the performance of them up substantially and you can make them shift just about any way you want with some time and trial and error.
Tyler
57taskforce is online now   Reply With Quote
Old 03-04-2026, 11:18 AM   #27
Rich84
Rich84's Avatar
Originally Posted by Sicklajoie View Post
All these new trucks are overpriced ****boxes IMO, I'll stick with my 03 Sierra with 6.0/4L80e with 255k miles. I bought it for $8700 in 2010 and it doesn't owe me a damn thing.
These are the greatest generation. Of all the trucks I have had for my drywall business they by far took the most abuse and held up well.
I put a 2005 6.0 4l80 in my 84 almost 10 years ago. Not one problem yet.
Rich84 is offline   Reply With Quote
Old 03-04-2026, 12:04 PM   #28
connorm
connorm's Avatar
As 57TaskForce said, after 2019 GM built the Allison badged transmissions, then Allison did the programming.
The 10 speed isn't the bad transmission, the 8L45 and 8L90's were the ones that had the bad torque converter issues. These do not seem to have a "fix". Last I heard Jasper Engines and Transmissions won't sell rebuilt transmissions because they can't sell a good unit.
I have the 6L90 in a 2016 GMC and this seems to be a fairly solid unit. It has sloppy a tune, and the torque converters have issues in some high mileage units. They also introduced the transmission thermostat in this generation and a lot of people claim this cooks the transmission and torque converter. Many people sell bypass kits for this.
1970 C/2500 Ol' Green https://67-72chevytrucks.com/vboard/...d.php?t=668003
2016 GMC Sierra K1500
1953 Mercury 2 Door Sedan https://67-72chevytrucks.com/vboard/...17#post9381817
connorm is online now   Reply With Quote
Old 03-06-2026, 11:28 PM   #29
Greg58
Greg58's Avatar
I have the 10 speed in my 2023 Silverado 3500, 4x4 Dmax. The trans is super smooth, pulls great! I have pulled my 9000# skid steer on my 20' heavy duty tilt trailer behind it with no issues. Also pull a tandem axle enclosed 16' trailer. Don't even feel it back there!
Love the power, love the truck.
Greg
________________
1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd.
2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold}
1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400
2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax.
Greg58 is offline   Reply With Quote
Old 03-07-2026, 01:53 PM   #30
GOPAPA
GOPAPA's Avatar
Greg
That's what I like to hear .. thx I had a 2006 Duramax with the 6 speed and liked it real well ,,I think my scare about this 2019 gmc gas rig is the amount of speeds it has .. more to go wrong I guess ,, but the more I find from people on here the more I have faith in the 10 speed ..with proper care that is .
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 03-07-2026, 11:55 PM   #31
Sicklajoie
The Niner
Sicklajoie's Avatar
Watch this video and your tune might change.
https://www.youtube.com/watch?v=m2GwZ0JPAMM
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 03-08-2026, 10:21 AM   #32
GOPAPA
GOPAPA's Avatar
I listened to the whole talk from NeXtgen and copied it so if I need transmission parts ,, I will talk to them about how to get the part put into my transmission and where to get it done ..thanks as it is a better solution it seems than putting another transmission the same as I have. in and have the same problem
I will add that it is sure hard to really believe "" any thing"" any more....
Old 03-09-2026, 03:37 PM   #33
Greg58
Greg58's Avatar
My previous truck was a 2007 3500 4x4 Duramax, I miss that truck. The LBZ engine is awesome, I never had a problem with the drivetrain while I had it. I think my new truck pulls a little stronger. Don't like the DEF, and I hear stories about DEF heaters going bad. Is your 2019 a heavy duty?
Greg
________________
