![]() Join Date: Jul 2000
Sanden compressor orientation and hose routing
Please post photos of your Sanden compressor and hose routing. Would like to see orientation of the compressor ports, how you secured the lines to the inner fender, etc.
Also, if it's Old Air system, show me where you mounted the heater valve and binary/trinary switch. Thanks. I'm in the middle of an Old Air installation. Hoses in the kit are extra long and cut-to-size.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 03-11-2026 at 01:39 PM. |
Re: Sanden compressor orientation and hose routing
Well, here's what I ended up doing. The compressor hoses flex enough for v-belt changing etc. Just need to get the hose ends crimped.
Still have to hook up the heater valve and hoses, and wire in the binary switch. Then I'll finish up the electrical, controls, and ducts. It's taken quite awhile, but I fixed or modified other things along the way.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Here is my factory setup with a Sandan conversion.
Very nice engine compartment, Rick. Did you convert to R134a?
I wouldn't mind having a factory air system that worked as well as the ones in the 70s-80s Chevys and Buicks I had back in the day.
Mike I did. New dryer, txv and adjusted POA valve. Just finished it up last fall. I think when I adjusted the POA I got the pressure just a tad low. Cools well but I think it should be better.
I positioned my line connections pointing up.
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
I considered that, but you can see from my above photo that a 90 degree rotation would clock the ports towards the engine.
Gonna get my hoses crimped today, install the heater hoses and valve, and start working in the under dash stuff. Had this setup on a 55 Chevy car, which was pretty tidy. Brackets were from Bill's Hot Rods, and the Tite Fit line set is from Vintage Air.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 03-31-2026 at 11:15 AM. |
Sanden sells the compressors with a variety of different rear heads. The heads can be ordered from different vendors to retrofit if you choose.
I cant stand the vertical outlets with the hoses sticking up in the air above the compressor. The horizontal outlets give a cleaner look, in my opinion. On some of the compressors the rear heads can be clocked, but not all.
'67 GMC 2500, 292, 4spd, AC |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Here is what I did with my 70 K10. You can probably see more in my build thread.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#10 | |
Anyone know if the smaller Sanden 508 style compressors can be adapted to be used with stock style compressor brackets? I really don’t like the Alan Grove brackets (looks wise).
I saw someone on a Vette message board say he used his stock brackets but his was a BB and I’ve got a SB. |
#12 | |
https://www.kwikperf.com/products/r4...version-k10606 https://www.oldairproducts.com/produ...mpressor-mount
I have a 72, so that setup wouldn’t work for me unless I wanted to go serpentine.
| Bookmarks |
