Old 03-15-2026, 09:27 PM   #1
r8rs4lf
Anyone add cruise control?
Beautiful day for a meet/cruise. Meet up spot was about an hour away and thought to myself sure would be nice to have cruise control.
Possible with a carbureted SBC?
r8rs4lf is offline   Reply With Quote
Old 03-15-2026, 09:49 PM   #2
jocko
jocko's Avatar
Re: Anyone add cruise control?
yes, it was a factory option, RPO K30
Old 03-16-2026, 12:37 AM   #3
pjmoreland
pjmoreland's Avatar
I installed cruise control in my K10 recently with parts I got from the local Pick-N-Pull.
https://67-72chevytrucks.com/vboard/...95#post9402895
I did the same thing 20 years ago in a 72 C10 I used to own.
https://67-72chevytrucks.com/vboard/...d.php?t=151318
pjmoreland is offline   Reply With Quote
Old 03-16-2026, 12:30 PM   #4
ThreeQuarter
ThreeQuarter's Avatar
Yes--entirely possible. The inputs are speed (speedo cable) and vacuum, with a brake pedal valve to break the vacuum to cancel (and an optional second one if you have a clutch pedal). It simply uses a vacuum servo to physically pull on the accelerator linkage, just like your foot does from the cab.
I installed one of RogerKoop's restored period-correct cruise systems in my '68. It is the simplest type of cruise: one button with SET and DECEL only. I went with the '69 transducer because we couldn't get the '68 version to operate smoothly. Love it. Of course there are less costly ways to do it with more functionality if you aren't a stickler for period-correct-ness. It would be relatively easy to adapt a cruise system from another GM carbureted vehicle, or find an aftermarket cruise kit from the 80s or 90s.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'94 Ford Explorer XLT 4wd
'25 RAM 1500 Laramie 4wd
ThreeQuarter is offline   Reply With Quote
Old 03-16-2026, 04:17 PM   #5
r8rs4lf
Where do I inquire about one of these systems?
I love simple!
Old 03-16-2026, 06:53 PM   #6
Rambler62
I put cruise on our 70 GMC and had it not been for a bad relay it would have been easy. I did take the easy mans way out and used Dakota Digital .
Rambler62 is offline   Reply With Quote
Old 03-16-2026, 10:03 PM   #7
ThreeQuarter
I love simple!
RogerKoop is a member of this board and posts his cruise kits for sale on the parts board (like this one). Reach out out to him--he may have some things he hasn't posted.
Dakota Digital is also a good place to check. Beyond that, I don't have any experience with any brand or vendor in particular, but an internet search should give you some options to compare.
Ben
Old 03-17-2026, 12:07 PM   #8
vics stuff
That K30 is a real rare option. I have never seen one on a SPID sheet before
Vic
vics stuff is offline   Reply With Quote
Old 03-17-2026, 02:26 PM   #9
Keith Seymore
Keith Seymore's Avatar
Vic
Agree.
At some point it got changed to K34, which is the RPO still in use today.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 03-17-2026, 04:45 PM   #10
doowopper
A lot of guys in my bike club installed Audiovox cruise controls and really liked them.
doowopper is offline   Reply With Quote
Old 03-31-2026, 10:01 PM   #11
saon
Rostra makes a universal kit. installed 1 on a 1967 lemans 326 pontiac engine.
works great. there are different button/switch options.
saon is offline   Reply With Quote
