Re: Gauge Mounting Advice/Ideas
You might want to take a minute and think about making the stock gauges work one at a time.
Oil: It's mechanical so it will probably work. Battery: It needs two voltage sources. Temp: If the engine isn't original, getting the right sender could be an issue. Speedo: Typically runs off the trans. Gas: New sender. Or, used nongauge clusters might be had from one of the guys who part trucks. Then you can drill and mount aftermarket gauges cleanly. |
| Bookmarks |
