Old 03-19-2026, 01:31 PM   #7
mrein3
mrein3's Avatar
Re: Gauge Mounting Advice/Ideas
Originally Posted by EagleChief View Post
A blank bezel could be an option, although I don't want to spend $200 on one. I have 2 factory bezels and one full set gauge cluster, so I was hoping to make one of them work.
Two things.
The way you say "I have two factory bezels, and one full set gauge cluster" makes me wonder if you had the idiot light configuration prior to the engine swap. If so, it isn't plug and play for full gauges. You need to move some wires around in the connector. Search this site for how-to.
My second point is, what engine did you put in? When I built my 383 it was still an old school flat tappet cam small block. Same temp sensor in the head. Gauge works fine. We can discuss using a flat tappet engine for anything at this point in life some other time. But I do know if you did say a vortec 350, that temp sensor won't work with our 67-72 gauge.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
