![]() ![]() Join Date: Feb 2009
Anyone have 15x7 front and 15x8 rear Rally Wheels on?
I have 15x8 but hear they wont fit the front due my 10c's 2.5" front spindle drop. Without modifications anyway, which I'm not doing. I collected some parts along the way and would like the Rally option.
A nice matching set of 15x7 are hard to come by, but two more easily achievable, so I wonder how it would look?? At the moment the truck sits level, not sure if I'd want to get tires to maintain that or perhaps a little lift in back, hmm.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Anyone have 15x7 front and 15x8 rear Rally Wheels on?
I have a set of Corvette rally's (unsure what brand they are) on my truck that are 15x7 front and 15x8 on the rear. I'm using Cooper tires 235/70-15 on the front and 255/60-15 on the rear. I also have drop spindles - lowered 3.5" in front and 5" in back.
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
15x7 with 255/60. 15x8 with 275/60.
It's not the best picture with the front tire in a dip in the driveway. Last edited by 3drburb; 03-16-2026 at 01:31 PM. |
![]() Join Date: Jan 2012
Member/Moderator leddzepp built a truck that looked a lot like yours and ran staggered 15x7 and 15x8 truck rallies on it. His build thread used to be on here but I can't seem to locate it.
Here's a couple pic of his truck I found on the forum. He was running a 5 and 7 drop. Not sure if he had to modify his A-arms or anything to make it work though. Maybe he'll chime in. |
![]() Join Date: Oct 2001
I don't have the rear axles changed yet but these are 15x7 Corvette style rallys from Speedway Motors with 235/60/15 tires. I have 2" ECE front springs and 2.5" dropped spindles. I went with the 7" wheels on front because I thought the 8" stuck out too far. Just my preference. The rear is getting 8" 255/60.
'69 swb stepside in progress. '59 Corvette lifetime project |
![]() ![]() Join Date: Apr 2022
I have wheel vintique 8 inch Corvette style rally's on all 4 corners of my truck. Im still 6 lug but no fitment issues with my dropped spindles.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
Wait, what sort of issues are you guys seeing with 15x8 on the front?
1969 C10 Shortbed |
#8 | |
I've heard the lower control arms are too close, possibly a ball joint issue too? I've also heard 8" wheels work with drops; how can both be true? Probably rhetorical. Thank you for images above. Nice trucks, and wow your set-up looks SHARP EagleChief, You had to have been "pleasantly surprised" when those were installed. FWW some images of my clearance, 2.5" drop with 6" OEM wheels - 235-75-15 tires are a little fatter than original.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-17-2026 at 08:53 AM. |
I'd bet that the folks have had issues with the rim or the balancing weights hitting the tie rod. I've run into that on S10's and my GTO with dropped spindles and 15 inch rally wheels.
A different backspacing of the wheel or a 1/4 -3/8" spacer will usually solve the interference problem.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
I’m basically building around a 15x8 front rally like thousands before me.
Hell, lots of people running 15x10 fronts even.
1969 C10 Shortbed |
#11 | |
Also you may be surprised how heavy the rally wheels are, I was, but I like the look. |
Like four anvils. I was also taken back the first time I picked one up.
1969 C10 Shortbed |
I keep seeing this one & the reply's with no mentions of WHY some people have issues with a certain wheel size while others don't. Nine times out of ten the interference issue is caused by the back-spacing of the particular wheel.
Width & backspace need to be stated in discussions about wheel/tire fitment. This will help others better understand why some combo's work where others had issues.
I have 15x8 with 275/60-15 tires all around. No fitment problems. I have lowering springs. I converted to 5-lugs when I lowered it.
1965 Malibu SS L79 Restoration Page 2004 Torrid Red GTO Preservation Page 2006 Brazen Orange GTO Preservation Page Rich Cummings Last edited by Rich69shortfleet; 03-19-2026 at 10:15 AM. |
#15 |
Thanks! I appreciate it! When I bought the truck it had some wheels from an early 2000's truck on it. I don't even remember the size, now. I bought the rally's off of my old boss for $100, then had our shop sand blast and paint them. Once they were mounted on the truck, it completely changed the way it looked. Then once the new suspension went on and the height was lowered, I knew that was where it was supposed to be.
#16 | |
____________________________________________________________________________________________________ ______________________ Check out this guy’s spindle drop with 8x15 Rallys. I nearly made the same mistake, almost pulled the trigger on having my 8x15 refinished. Geezuz, by the time I bought tires too only to find.... https://67-72chevytrucks.com/vboard/...d.php?t=677631 Same thread says the backspace on a 7x15 rally wheel is 3.5/8 ____________________________________________________________________________________________________ ______________________ This thread says the 8/15 rally wheel has a 4” back space. https://67-72chevytrucks.com/vboard/...d.php?t=363898 ____________________________________________________________________________________________________ ______________________ Write-up on Rally Wheels. https://67-72chevytrucks.com/vboard/...d.php?t=462895 Says 4.25” backspace on a 8x15 Rally Wheel. He speaks of a lip, not sure what that means. I measured mine which was slightly less/more, maybe I’ll see if I can find the thread or measure again (Edit is last paragraph). I'm 80/20 sure you’re supposed to measure from below what he may be calling a lip, but I suspect he means outer aesthetics. Like another source he says the back space on a 7x15 Rally Wheel is 3.5/8. _____________________________________________________________ EDIT: I found some of my notes. I measure dead nuts 4.3/8 (4.375) backspace on my 8x15 rally wheels. So you got three choices, one guy says 4", another 4.25" and mine 4.3/8" I suppose it's possible some variances in Rally Wheels. Something tells me no......... An image for back space.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-19-2026 at 11:17 AM. Reason: Add clarity |
#17 | |
#18 |
[QUOTE=SCOTI;9426962]I don't recall there being an area on the hub or rotor surface that is recessed for the 'ring' (?).[/QUOTE
Beyond the hub might be better term.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-19-2026 at 11:11 AM. |
| Bookmarks |
