Old 03-08-2026, 11:56 PM   #1276
pjmoreland
pjmoreland's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Also got the A/C evaporator box mounted under the dash. Had to remove the mounting bracket from the back of the box to get it to clear the bottom edge of the dash. It was not fun reinstalling it in place.
Reinstalled the carpet and melted a hole in it for the condensation drain.
Installed some new heater fittings on the engine. Both heater hoses will be 5/8, so the water pump fitting is smaller than stock.
pjmoreland is offline   Reply With Quote
Old 03-09-2026, 12:00 AM   #1277
pjmoreland
pjmoreland's Avatar
Also mounted the compressor. Had to bend the dipstick tube out of the way.
Old 03-09-2026, 02:39 PM   #1278
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks great! Nice work
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-09-2026, 02:41 PM   #1279
pjmoreland
pjmoreland's Avatar
Thanks, Dale
Old 03-09-2026, 11:40 PM   #1280
pjmoreland
pjmoreland's Avatar
Installed the condenser. Gonna have to remove the grille to get the lines installed.
Old 03-13-2026, 12:15 AM   #1281
pjmoreland
pjmoreland's Avatar
Was able to get the condenser hard lines routed through the hole in the radiator support by loosening the grille and tipping it forward. Also installed the compressor drive belt.
Old 03-15-2026, 04:51 PM   #1282
pjmoreland
pjmoreland's Avatar
Installed the A/C hoses and heater hoses. Also installed a thermostat bypass hose from the intake manifold to the water pump so that coolant can circulate while the engine is warming up now that the coolant can't circulate through the heater core. Vortec small block engines lack the bypass channel from the water pump up through the passenger side head.
Old 03-15-2026, 11:53 PM   #1283
SRU1436
Looks great, is that the gen 5 version?
SRU1436 is offline   Reply With Quote
Old 03-16-2026, 12:18 AM   #1284
pjmoreland
pjmoreland's Avatar
Thanks. It is gen 5. I installed a gen 5 system in my other truck in 2023, and the only change I've noticed is that they no longer offer the option to put potentiometers on the stock heater controls. They now include their heater controls, and they've raised the price accordingly. I prefer the look of the OE controls. I'll have to come up with a good way to cover up the tacky Vintage Air logo on the controls.
I had a funny argument with the guy that took my order for this current system. I told him that my previous system was a gen 5, but he was convinced that gen 5 was not available in 2023. After a little digging, he concluded that it was indeed an early release of the gen 5 system. It said gen 5 on the invoice and on the installation instructions after all.
Old 03-19-2026, 05:36 PM   #1285
Ol Blue K20
Very clean installation, Very nice
Dale
Old 03-19-2026, 05:43 PM   #1286
pjmoreland
pjmoreland's Avatar
Thank you, Dale
Old 03-21-2026, 08:57 PM   #1287
pjmoreland
pjmoreland's Avatar
Worked on the wiring today. Started by connecting into the switched power and dash illumination wires in the stock harness. Used a stock connector.
Old 03-21-2026, 09:01 PM   #1288
pjmoreland
pjmoreland's Avatar
Connected the main VA harness to the controller. Installed the heater controls and ran its cable to the controller. Ran the wires along the inner front edge of the dash along with the radio antenna.
Old 03-21-2026, 09:09 PM   #1289
pjmoreland
pjmoreland's Avatar
Moved to the engine bay. Installed a little fuse panel by the battery in place of the stock 12V terminal. Also installed a relay for the compressor next to the fuse panel. Wrapped the wires passing through the firewall in the provided loom and ran the wires inside the fender over to the fuse panel. Connected the necessary wires to the fuse panel, relay and binary switch.
Old 03-21-2026, 09:12 PM   #1290
pjmoreland
pjmoreland's Avatar
A few more photos
The lights on the heater controls are a bit overly bright in my opinion. Oh, well.
Old 03-21-2026, 09:21 PM   #1291
'68OrangeSunshine
'68OrangeSunshine's Avatar
Originally Posted by pjmoreland View Post
A few more photos
It's not like you could put a slice of Blue theatre gel over the lights.
[But I do work backstage and could send you some scrap gel. -- It's really plastic now -- they haven't used gelatine in theatrical lighting media for about 60 years.]
What about a resistor inline with the illumination power?
Also, do you have a Heater now?
Old 03-21-2026, 09:28 PM   #1292
pjmoreland
pjmoreland's Avatar
A dark plastic film could possibly tame the lights discretely. I might just disconnect the lights altogether depending on how annoying they are at night. The Vintage Air system includes a heater. The heater core is now in the box under the dash along with the evaporator.
Old 03-21-2026, 11:18 PM   #1293
'68OrangeSunshine
I can send you a piece of dark plastic film, aka ''Theatre Gel''.
I think I have some scraps at home. Medium Blue OK?
I may want to look into a VA system for the Jimmy. Had Production A/C new. Now long gone, and heater is disconnected.
Old 03-21-2026, 11:45 PM   #1294
pjmoreland
pjmoreland's Avatar
That would be great. Thank you. If you have any in green, that would work, too
Old 03-21-2026, 11:59 PM   #1295
SRU1436
Install looks great, good job. I put a gen 4 system in my chevelle. Contemplating the gen 5 system or just a smaller under the dash system asi don’t want to lose the glovebox like I did in my chevelle.
Old 03-22-2026, 12:03 AM   #1296
pjmoreland
pjmoreland's Avatar
This system I'm installing reduces the glovebox size significantly. Here's a photo of the gen 5 glovebox in my other truck.
Old 03-22-2026, 07:27 AM   #1297
'68OrangeSunshine
I'll have to ask the LX Dept for green gel next time I work there.
[''LX'' = Electrics.]
Old 03-22-2026, 08:02 PM   #1298
SRU1436
Seems about the same on my chevelle.
Old 03-23-2026, 12:44 AM   #1299
pjmoreland
pjmoreland's Avatar
Installed the ducts under the dash. One challenge is that they have to be installed one at a time, but some of the ducts get in the way of other ducts, and there is basically no extra duct material. My driver side defrost duct ended up a little shorter than I'd like, but it fits. I should have cut the passenger defrost duct first. I couldn't get the duct onto the dash center vent with it installed, so I had to remove it, attach the duct and then reinstall it. I reinstalled the speaker and radio after that.
Old 03-23-2026, 12:46 AM   #1300
pjmoreland
pjmoreland's Avatar
A few more duct photos
