Old 03-29-2026, 07:49 PM   #5701
dave6672
dave6672's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by CG View Post
That’s a great look you have going!
Thanks, appreciate it!
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
1972 C10
dave6672 is offline   Reply With Quote
Old 03-30-2026, 01:06 AM   #5702
'68OrangeSunshine
'68OrangeSunshine's Avatar
Originally Posted by zicc1835 View Post
finally installed these tie down brackets OLD TRUCK FAN offers these.... nice option IMO
I wonder what the shear load is on those two Grade 5 bolts?
Old 03-30-2026, 01:23 AM   #5703
'68OrangeSunshine
Today I extracted the Speedometer from my '67 K/10 Suburban's instrument cluster, and used it to replace the Speedo in my '68 C/10 Stepside.
Mechanically, the operation was OK, but electrically, I failed somewhere.*
I have no Dash Lights. Cab [Dome] Light works OK. Hazard Flashers work.
The Left Turn Indicator bulb is constant ON.
It was dark when I knocked off for the day. With no instrument lights, I did not test run at night. In the daylight, I will test run the Stepside to see if the Speedo reads right. Before, the OEM Speedo was running very slow. 35 MPH indicated when GPS read 50 MPH groundspeed.
A friend offered to recalibrate the unit.
* I believe there is an Open where the rectangular plug for the Cluster Connector meets the copper leads of the Printed Circuit. One of the plastic tabs on the Connerctor side broke off a couple years ago. I got a new one mail order, but now I can't find it. Also about 3 of the copper leads on the PC are loose.
I think the Connector wobbled loose when I had to wiggle the Panel around to get to the six screw holes.
Tomorrow is another day.
Old 03-30-2026, 01:35 AM   #5704
'68OrangeSunshine
Pix of Speedo transplant:
Old Yesterday, 09:49 PM   #5705
zicc1835
zicc1835's Avatar
in response to your shear load question
well they say a picture is worth ...how many words
second pic if I ever thought I would tie down something remotely heavy in the back of my sweet little stepper when I remove the bed to fix the POs bed work minus the side angles I would put some reinforcing brackets on the back side of the head board and some grade eights and then I can haul around something more exciting like one of these......just sayin never contemplated heavy hauling but like the option to tie down a cooler or chair for a trip to a show
zicc1835 is offline   Reply With Quote
Old Yesterday, 09:53 PM   #5706
zicc1835
zicc1835's Avatar
Originally Posted by Chevys4life View Post
Is the website called Old Truck Fan? I want to get a set for my truck too.
sorry Chevys4life I missed this question .... Old Truck Fan is a board member type him into members list you'll find him he Adam easy to deal with
Old Today, 07:21 AM   #5707
Chevys4life
Thanks!!!
Chevys4life is offline   Reply With Quote
Old Today, 09:12 AM   #5708
'68OrangeSunshine
Nice placement. Can you reach out of the cab thru the window and grab a cold one?
Old Today, 10:25 AM   #5709
70STOVEBOLT
70STOVEBOLT's Avatar
Originally Posted by trapdoor2 View Post
Just a little update, I haven't been here on the forum in a while.
The C10 has been in storage for a while but last month we finally found a good local speed shop and had her rollbacked off for reinstatement, updates and rework.
The job: update distributor to HEI. Update brakes to power discs on all 4 corners. Install 3:53 diff and posi. Install 2" hitch. Modernize A/C. Install upgrade headlight harness with relays, etc. New 15" steering wheel. New "orignal look" instrument panel, added tach.
What happened: all of the above + new wiring harness in cab (found shade-tree household wiring, duct-tape repairs and a general mess). New wiring aft of cab, same issues...+ added hitch wiring. New Holley carb...the original had worn shafts, linkages, etc. New shoes (radial T/As again).
Miz Diane is just back from her test drive in the picture. It's her truck...she just lets me drive it.
That's a nice looking truck Miz Diane has. Do you have a build thread or more pice of the interior and engine bay?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
