Old 10-02-2004, 12:12 AM   #1
bigblock73
yeller
bigblock73's Avatar
new toy....literally
Not sure if anyone here is into R/C or models, but for those who are, I thought I would share with you my latest creation.
This is a 1:10 scale radio controlled replica of my truck (with the exception of the front clip, mine is a 73). It is a Clod Buster body on a M04-L chassis..both of which are Tamiya products. I had to shorten the box, and shave the sunroof hole, hood scoop hole, hood tilt lines, and vent windows (just for looks). I still need to do some detail painting on it (lights, handles, etc) and make a box cover. This should be fun to bring with to shows...when my real truck is finished.
Now before anyone rags on me, I have been working on Yeller too!
bigblock73 is offline   Reply With Quote
Old 10-02-2004, 12:52 AM   #2
kballan
kballan's Avatar
Jeff, that's freakin' awesome! Okay, spill the details - how much and where did you shorten the bed? Also, what did you use to fill the sunroof and hood scoop hole? I've been wanting to use a Clod Buster body myself for the exact same thing for a long time now, but didn't know what chassis or anything to use. Again, that's a great toy! Looks awesome to see the real thing!
Kent Ballan
ANY MAN CAN BUILD A TRUCK, BUT IT TAKES A REAL MAN TO CUT ONE UP!
kballan is offline   Reply With Quote
Old 10-02-2004, 01:30 AM   #3
87 Shortwide
Ive got a handful of RC cars, but nothing with an 80s pickup body
I have 3 RC10 buggys, 1 RC10 truck, Parma 37 chevy, 32 coupe, and 56 wagon, an AWD electric car, AWD gas car, an E-MAXX, and a T-MAXX.
No Im not obsessed at all!
Daily Driver: 1992 Blazer dropped on rallys
Project: 87 GMC shortwide, About to get a little boost
87 Shortwide is offline   Reply With Quote
Old 10-02-2004, 02:06 AM   #4
PHOENIX
I love it, any pictures of it in action?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 10-02-2004, 04:16 AM   #5
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Daz Niiice
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 10-02-2004, 08:44 AM   #6
Blue Beard
Blue Beard's Avatar
Very nice job, will be even nicer detailed.
I still have a couple in the garage that were detailed even with working head lights. Won several tropy's with them.
After that raced them both, had near 5k into the two rigs. But they performed.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-02-2004, 08:51 AM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
damn thats badazz
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 10-02-2004, 08:57 AM   #8
bigblock73
yeller
bigblock73's Avatar
Kent, when I get home I will measure and see how much I removed from the bed. All the material was removed from the front of the bed. It is a little out of proportion due to the chassis wheelbase, but close enough. It is actually closer to a Blazer/Jimmy wheelbase...and it would be pretty easy to make one of those too (Ken, you reading this? ). The chassis is from the Tamiya BMW Roadster kit. It is rwd, and has 4 wheel independant suspension. I put ball bearing in it to make it faster and more battery friendly. As far as filling the holes...I cut some thin aluminum slightly larger than the opening, and epoxied them from behind. I then filled the recessed areas with automotive bondo. It was a very simple procedure.
87 shortwide. I have a couple other R/C's. I have a hopped up Midnight Pumpkin, Grasshopper converted to a monster truck (it too will have a 81+ Chevy body), and a basically stock E-maxx. I used to race a Losi T, but sold it because I was always spending money on it in order to keep up with everybody else.
Old 10-02-2004, 09:01 AM   #9
Liz
Catchy title goes here..
Liz's Avatar
thats sweet Jeff , Piston ( MOT ) just started R/C forums, set up like these. I haven't had mine out since before Dan was born (kinda like my truck ) anyways, you should check out his new R/C thingy here its just starting up but has the potential to be cool.
Liz is offline   Reply With Quote
Old 10-03-2004, 01:31 AM   #10
kballan
kballan's Avatar
[QUOTE=bigblock73]Kent, when I get home I will measure and see how much I removed from the bed. All the material was removed from the front of the bed. It is a little out of proportion due to the chassis wheelbase, but close enough. It is actually closer to a Blazer/Jimmy wheelbase...and it would be pretty easy to make one of those too (Ken, you reading this? ). The chassis is from the Tamiya BMW Roadster kit. It is rwd, and has 4 wheel independant suspension. I put ball bearing in it to make it faster and more battery friendly. As far as filling the holes...I cut some thin aluminum slightly larger than the opening, and epoxied them from behind. I then filled the recessed areas with automotive bondo. It was a very simple procedure.[QUOTE]
Thanks for the info Jeff! Much appreciated! I can't wait to see yours when it's done!
Kent Ballan
