#26 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#27 |
Here's the ones I took last night. (No measurements of mounts)
1st thing I would check to see if the each set of mounts are the same from one side to the other. (Wrong bushing used?) Also if you see one that apears to be smashed may want to check that the tube (item 4 in bolt pic) was used. 2nd would sugest taking a torque wrench to the bolts to see if they are the same. (Could be that one is to tight or never was tight.) Could not find torque for 1st mount, but all others were 15 -24 Ft lbs. Would say front should be the same also. Also included the one of the door wedges. 3rd add or remove shims... The one I had to show the front fender to door gap was not clear. Will try to get it later if needed. Hope these help.
1972 C10 SWB 350 / T400 1972 SWB GMC 350/T350 1972 Cheyenne 20 super "long horn". 402BB / T400 1972 Suburban C10 Deluxe 350 / T350 and a few more.. http://www.myspace.com/afew72s |
#28 |
![]() Join Date: Dec 2002
I am not saying they have the measurements I haven't actually looked but LMC very detail I ordered all new bolts and washers etc for my kit that I already had from them
#29 |
The LuvShack Garage
THANKS GUYS, HOWEVER I'M BACK TO PAGE ONE AGAIN
![]() THE PARTS BOARD, THANKS "AFEW72'S", WISH I'D NOTICED B4 PRIMER WORK. ![]()
#30 |
#31 | |
The LuvShack Garage
FROM CALI, THEY NEED JUST A LIL BODYWORK TO BE PERFECT AND I AM TIRED OF SHELLING OUT CASH FOR BODYWORK, TRYING TO SAVE UP TO GET HER PAINTED IN THE SPRING & I KEEP GOING BACKWARDS. ![]() http://67-72chevytrucks.com/vboard/s....php3?t=128837
#32 |
PROJECT 7DEUCE
Hey luv you really need to get the 1967-72 chev/gmc truck assembley manual it has helped me out of almost evey tight spot I have gotten myself into..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#33 | |
The LuvShack Garage
