Old 05-24-2008, 02:57 AM   #26
billydonn
Council of the Elders
billydonn's Avatar
Re: 5 lug axles
Originally Posted by gnhuntin View Post
I bought a 79 C10 for the front end parts (ps, disc brakes, etc) to use in my 66 C10. Question, can I use the axles out of the 79 and just cut 3/4" off the end and cut a new groove for the c-clip or is the spline different or not long enough to engage the spider gears properly?
I would be skeptical of that plan because of the spline/spider gear issue you mention, and it would put your new c-clip groove in the old spline area of the axle wouldn't it? Probably a better idea just to transplant the whole 79 axle assembly (assuming the length and everything else is right, which I can't testify to.)
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 05-24-2008, 03:06 AM   #27
GKsport67
GKsport67's Avatar
Re: 5 lug axles
I will keep the stock housing n change the guts out with ECE products! they seem to understand our needs.
GKsport67 is offline   Reply With Quote
Old 08-23-2008, 10:59 PM   #28
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Re: 5 lug axles
Anyone know the standard bolt pattern for an '87, 5x?
Thanks in advance.
Kenny
87Lowrider is offline   Reply With Quote
Old 08-24-2008, 12:41 AM   #29
Captainfab
60-66 Nut
Re: 5 lug axles
Thanks in advance.
Kenny
5 X 5....or 5 on 5" however you want to say it.
Old 08-25-2008, 12:19 AM   #30
olsofti
olsofti's Avatar
Re: 5 lug axles
'63-'64 have 17 splines,65-66 have 30.
olsofti is offline   Reply With Quote
