Re: C10Slim's 66 Build Thread
Got the driver side done and most of the pass complete yesterday.
Question...Where did u order the floor/rocker panels from and which ones did u get exactly?
Roadhammer |
#4 | |
![]() They are the Triplus panels from what I have heard are the best out there. |
Member of the longbed union.
good looking patch work
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
what did you use to shave the gas filler?
#7 | |
Martin Gibson
USAF Retired 1964(-ish) C10 |
Sunburst C10!!!
wont that leave a flat spot where the hole used to be?
Gage 1967 C10 Shortbed Stepside |
ok just wondering if you bought a patch for it or not. I have to do the same thing so just trying to figure the easiest way.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I always make a pattern like he did and cut out the metal with a pair of hand held tin snips. Hold it in place with a magnet and weld it in.
thanks for the info guys
#13 |
Today's goal was to get the cab off the frame. Stripped the steering components and called some buddies!
#14 |
Pulled the motor and tranny today. Also power washed the front half of the frame so I can disassemble with out fighting 40+ years of grime.
#15 |
Found the answer to my question.
#16 |
Rear suspension removed tonight. Front will be broken down tomorrow.
#17 |
You messed up. It's always fun to play in 40+ years of grim.
#18 |
Today pulled all the front suspension and started poping rivets on the trans and trailing arm crossmembers. Hopefully tomorrow I can flip it and finish the bottome rivets. Then be ready to blast and paint.
#19 |
Today was a good day and a craptastic all at the same time. First got the c-notch in and the frame cleaned up. Painted the center link and crossmember. The while I was admiring my work I a hear a bang. I turn to look and the neighbor has just backed in to my car!!! Sucks!
#20 | |
![]() Join Date: May 2009
#21 |
This week I KBS coated the frame, painted and reinstalled the re-used suspension parts along with the new goodies...
![]() Last edited by C10Slim; 10-04-2009 at 09:29 PM. |
#22 |
Couple more...
#23 |
Hopefully everything you ordered is there, but it's looking up.
#24 |
Got some catch up to do now that the attachments are back
![]() My new mechanic has been helping me out quite a bit lately. Once she gets started she doesn't want to stop. Almost brings a tear to your eye don't it? |
#25 |
Few more
