#26 |
Rods
![]() Join Date: Nov 2002
Re: Disc swap track width questions
ill get the pics to you tomarrow,I have then in a file.
i WISH YOU HAD THE PICS. ITS JUST NOT THE SAME WITHOUT THEM
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) Last edited by 70 Suburban; 11-04-2009 at 10:13 AM. |
#27 |
I know that the correct upper ball joints will press into the 63-66 upper arms. Will the whole 73-87 3/4 ton upper arm bolt up? The idea being that you could have newer style rubber bushings on upper and lower A arms, and the 2000 spindle and brakes bolt in, for a 6 bolt conversion, using a 3/4 ton donor.
Ralph |
#28 |
Rods
They dont press into the upper they bolt in.. You can use the upper arms from the 1/2 ton and 3/4 ton also
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) Last edited by 70 Suburban; 11-04-2009 at 06:55 PM. |
#29 |
"They dont press into the upper they bolt in.. " Yeah, i goofed. Guess I had the lowers on my mind. So the upper A arms can be used too! Thanks!
Ralph |
#30 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The 3/4 ton LCA's that I've seen used the steel bushings on the shafts like the '63-'72 1/2 ton LCA's That's not to say that somewhere in the mid to late 80's they don't have the rubber bushings, I just don't recall seeing ones in those years.
#31 |
Rods
Mine are from 87 3/4
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
#32 |
60-66 Nut
I just re-read your install instructions, So apparently they have the rubber bushings. I wonder when GM made the change?
Learned something new today ![]()
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 11-06-2009 at 01:06 AM. |
#33 |
Rods
They went in like a charm.and it took the sqeak out of the front.
#34 |
60-66 Nut
Yeah I hate listening to that squeeking while driving slow.
