#26 | |
Re: 4 link !
#27 | |
Still plays with trucks
Re: 4 link !
http://qa1.thomasnet.com/item/pro-dr...10&plpver=1001 General info: http://www.qa1.net/qa1_motorsports/ I found this while looking for the QA1 info http://www.kw-suspension.com/us/kw_p...nPage=coilover
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#28 | |
Re: 4 link !
If you like this setup and want the bars on the inside, just swap the front brackets so the origninal left front bracket is on the inside of the right framrail and vise-versa. Just box in the frame rail (after you weld the nuts on the backsides of the holes)and weld the bars inside the fraimrail. If your lower shock mounts are too close then you could weld in new lower mounts if it is a problem.
