Old 01-21-2010, 08:08 AM   #26
billnorman
Re: New engine, won't run!
Well...I agree with Pyrotechnic. That's how we always did it with engines that may have been assembled a little different than factory specifications. However, first and foremost you must have compression. After you verify you have adequate compression, then do the finger in the hole trick to validate that you are on #1 COMPRESSION STROKE. Also, validate that the timing mark is coming to alignment with the TDC indicator. If it's not, the damper is defective, installed wrong or the wrong one. If necessary, make a TDC locator out of an old spark plug with the porcelean removed and a rod welded through the middle. Remove the plugs and rotate the engine through by hand with a torque braker bar and socket on the crankshaft bolt to validate the TDC mark. Once TDC is validated, get on the compression stroke and wire the distributor cap so that the next plug wire the rotor gets to is #1, followed by 8,4,3 etc. Be SURE you don't have a distributor cap that has the internal jumpers so that all the plug wires come out on the same side of the engine that they go to. This will screw you all up. If it still won't run, leave the plugs in and hook a timing light to the #1 cylinder wire. While cranking, see where the spark flashes the light on the vibration damper. If it's right, and you have compression and fuel, it must run.
billnorman is offline   Reply With Quote
Old 01-21-2010, 11:29 AM   #27
Damien
Damien's Avatar
Sorry guys. I thought about what was posted last night while I was at work. If the timing set is off 180* then the dist will be off 180* And as someone said it won't matter. The dist just needs to be turned 180*. I don't know what the hell I was thinking.
Billnorman may be on to something here. The balancer could have the wrong markings, and if that is the case you might want to make sure it has the correct balance for the engine. I believe the 396 is internal and the 454 is external.
The spark plugs probably are not the problem. Even if they did get wet from the wd40, I would think they would be dry after a day of sitting. How are you testing spark? You should use a spark tester. Arcing off a screw driver can give too small of a gap. So there may be enough spark to jump a small gap, but not enough to jump the gap on the spark plug in the cylinder. Do you have a full 12 volts to the coil? Could it be the ignition module?
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 01-21-2010, 11:57 AM   #28
68Timber
I know the pieces fit
68Timber's Avatar
That one has bit a few people.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-21-2010, 12:38 PM   #29
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by brothers69c-10 View Post
Everything you all have said about the distributor i have tried. I cput the distributor right on and 180 off, moved it a tooth either way from those positions and nothing. I check tdc just like you all have posted. But now on to something new.....
I've been thinking about the dry cylinder deal with puting oil in the cylinders. I had forgot that when i was checking the starter out i sprayed a ton of wd 40 down the spark plug holes. I would almost bet since wd 40 does evaporate quickly especially with the plugs in the motor, that when gas hits the plugs its more or less flooding the engine. So i am thinking that if i pour some regular motor oil down the holes and crank that thing over alot and clean the cylinders out, that it may run. What do you guys think?
Worth a try. WD40 is pretty thin and displaces other fluids plus it dissipates pretty quickly. The cylinders could be dry by now.
I would change your oil too as all that gas and WD40 has run into the oil pan and contaminated your oil by now. No sense taking the chance on hurting a fresh engine over $15 worth of oil and filter.
Make sure you have a fully charged battery too. HEI's don't like to fire when the voltage is low.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 01-21-2010, 01:06 PM   #30
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Uhh...are you absolutely positive you're getting fuel?
Will it start and run when a dab of fuel is poured down carb?
I've seen guys chase problems only to find out that either the fuel pump isn't pumping, clogged filter, vaccum leak or the carb has a stuck float.
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 01-21-2010, 01:11 PM   #31
68 TT
68 TT's Avatar
Or there is air in the fuel line and the pump isn't getting any fuel to the carb.
Old 01-21-2010, 03:21 PM   #32
Rob73-87
Rob73-87's Avatar
hmm, - if the timing`s correct - and the distributor positioned corecctly, too. Fuel is there, - THEN I think it should be a defective spark module in the dizzy.
I have had exactly the same prob - I couldn`t imagine that I might have problems with the distributor because I actually HAD SPARK on the plug....
After I replaced the module it ran.......
1982 C-10 SWB (soon dropped, 383ci, but restored stock appearance)
1984 C-10 LWB, dropped, custom paint
1996 Plymouth Voyager (Daily Driver "The Mule")
2008 Caliber R/T (Daily Driver)
Rob73-87 is offline   Reply With Quote
Old 01-21-2010, 03:45 PM   #33
dan76
Status report requested.....
dan76 is offline   Reply With Quote
Old 01-21-2010, 04:49 PM   #34
69BBsuburban
Especially if it's a dual tank truck....if the fuel valve has a small, internal leak and one tank is empty, it's basically a vacuum leak and no fuel is drawn from the tank with fuel....
I just fixed this problem on my own truck after much frustration trying to find the issue...
Pinstriping by Josh
1930 Ford Model A
Old 01-21-2010, 07:27 PM   #35
LONGHAIR
Longhair, You are wrong. The timing marks on a chevy small block V8 neet to be together when installing a timing set.
Wow Damien, that's pretty harsh....especially when I am not.
No, he is right, it won't matter where the dots are as long as they are both up or both together in the middle. Since the crank spins twice as fast as the cam it will work either way. Now if they were off a tooth or two it could make a big difference.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-21-2010, 09:14 PM   #36
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
Its got gas, I checked this by pulling he screw out of the side of the bowl. If your pour gas down the engine it quits firing all together. I tested the spark by pulling the plugs out and laying them on the frame rails and had somebody turn the engine over and watched them all spark a pretty blue spark. The balancer is new and it is right on the money for when the cylinder is on tdc. Still don't think it would be the distributor as it's only been off a running engine for about 3 weeks.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 01-21-2010, 09:53 PM   #37
britnjc
britnjc's Avatar
octane, octane, octane
britnjc is offline   Reply With Quote
Old 01-22-2010, 10:49 AM   #38
LONGHAIR
I find it hard to believe that "low octane" would make the motor fail to fire completely. It may not be optimal, but it should fire up just the same.
Octane rating does not relate to the energy content of the fuel. It is only a measure of the fuel's tendency to burn in a controlled manner, rather than exploding in an uncontrolled manner. So a lower octane fuel may be a lot more suscpitable to pinging, but it should start in at least idle just fine.
Higher octane actually supresses the flame to a more controlled burn.
They do start Nitro-Methane powered engines with a squirt of gasoline after-all....
Old 01-22-2010, 11:18 AM   #39
brothers69c-10
Suburban Hick
I agree with longhair on the octane rating. The compression ratio on a tall deck at most is usually only 9:1
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 01-22-2010, 11:51 AM   #40
thepartsguy
thepartsguy's Avatar
Have you checked the valve adjustment? I know big block valave trains are critical
thepartsguy is offline   Reply With Quote
Old 01-22-2010, 11:58 AM   #41
Alex1
Alex1's Avatar
Even if it was 14:1 it would fire on 89 octane.
Alex1 is offline   Reply With Quote
Old 01-22-2010, 02:16 PM   #42
britnjc
britnjc's Avatar
I am by no means a motor guru, but it is something to try. I am just going by one of my fellow hotrodders and good friends has a 468 big block with 427 heads buit with a blower pushing about 700 HP and he put pump gas in it and got to where it would not even fire. He started putting 110 octane in it and that beast came to life and hasnt had trouble with it since, except for the fact you cant drive it without burning the tires off it(if thats a problem). Now the motor that is being refered to here may not be built quite like the one im refering to but that was my experience.
Old 01-22-2010, 02:50 PM   #43
Alex1
Alex1's Avatar
That blower motor would only have between 7.5 to 9.5:1 so no need for fancy fuel when it's out of boost. Lower octane fuel is EASIER to light.
Old 01-22-2010, 04:26 PM   #44
Rob73-87
Rob73-87's Avatar
Try another distributor - if you don`t have a second one - try to borrow one from a friend or so.
Old 01-22-2010, 06:00 PM   #45
LONGHAIR
There had to be something else going on there, water in the lower octane gas? ...something? Just changing to a higher grade was not the only factor there.
Back to the original poster....I am still going to bet on timing. There is either a problem with the distributor itself, or the timing is way off.
Old 01-22-2010, 07:58 PM   #46
aboveall
Junior Member
i had a 427 tall deck in my dually and then put in brand new 502 the distributer i had had an ajustable coler on it you can get a new distributer with that color you ajust where you whant you distibuter to be but one you do that keep the gasket off put distributer in place tighten down the color where needed and the put gasket back in place that gives you the axsact gap you need i had to do that from my 427 tall deck to the 502 hope you understand
aboveall is offline   Reply With Quote
Old 01-22-2010, 08:02 PM   #47
aboveall
Junior Member
a regular distributer will not work its to short you need longer for the tall deck moter
Old 01-22-2010, 09:39 PM   #48
MR .T
MR .T's Avatar
Do you have a good engine to chassis ground?
MR .T is offline   Reply With Quote
Old 01-22-2010, 09:50 PM   #49
68Timber
68Timber's Avatar
Have you checked this? It's easy to check volts at the coil and any of the 'Zones' will check your module for free.
John
74 Honda Z50 build
Old 01-22-2010, 10:57 PM   #50
brothers69c-10
Suburban Hick
There is a thread on here that discusses distributors for tall decks. I f you use a stock tall deck intake manifold you can use a normal distributor. Mine turns just fine and engages the oil pump. The only time you need an adjustable collar distributor is if you use an aftermarket intake or an intake from a regualr big block.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
