Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 05-04-2010, 10:58 PM   #26
Captainfab
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
I haven't seen any on their website. Their rear disc brake kits appear to use the internal shoes for the e-brake like GM does on later model vehicles.
Originally Posted by Burb View Post
Ok ... does Wilwood make a D52 replacement w/ E brake ?
Old 05-05-2010, 12:17 PM   #27
Burb
Coordinator of Synchronicity
Burb's Avatar
Bummer
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 05-07-2010, 02:01 AM   #28
Captainfab
60-66 Nut
I came across this nice proportioning valve today that might be of interest to you guys doing the 4 wheel disc conversions. It has a built in adjustment knob. They are a good price also. About 1/2 the price of an aftermarket fixed proportioning valve.
http://www.summitracing.com/search/?...60-11179&dds=1
It is available from Jegs as well if you prefer doing business with them instead.
Old 05-08-2010, 03:57 PM   #29
toms84ss
Wilwood shows four different calipers on their web page. Two for the 1" rotors and two for the 1.25" rotors. The difference between them is piston area. Any one know the in's and out's of choosing the correct one? I would think the larger piston area would equal more pressure applied to the rotor. But I'm no expert.
toms84ss is offline   Reply With Quote
Old 05-08-2010, 08:19 PM   #30
lolife99
67-72 parts collector,…
lolife99's Avatar
Larger piston is for the front.
Smaller piston is for the rear.
Keith
Convert to disc brakes.
Old 05-08-2010, 11:43 PM   #31
toms84ss
Cool, thanks.
Old 06-23-2010, 01:37 AM   #32
Captainfab
60-66 Nut
There have been inquiries as to what the overall cost is for a rear disc conversion using my brackets. So I have put together a listing of the associated conversion costs for all 3 of the rear disc brake conversion brackets that I sell. Most of these prices I found online on Schucks/O'reilly's website. So anyone should be able to buy these parts for these prices.
Astro Rotor with D52 Calipers
  • Brackets $242.00
  • Rotors $67.98
  • Calipers $71.98 (includes core charges)
  • Pads $22.99 (semi-metalic)
  • Hoses $26.98
  • Banjo bolts $6.58
  • Total $438.51 (with front calipers, no e-brake)
  • $124.00 (add for e-brake style calipers)
  • Total $562.51
'93-'97 F-body caliper conversion The sale thread can be found here http://www.67-72chevytrucks.com/vboa...d.php?t=382633
  • Brackets $112.00
  • Rotors $107.98
  • Calipers $319.98 (includes core charges)
  • Pads $19.99 (semi-metalic
  • Hoses $21.98
  • Banjo bolts $6.58
  • Mounting hardware $15.00 (estimated)
  • Line adapters $5.58
  • Total $609.09
'94-'96 Impala SS caliper brackets The sale thread can be found here http://www.67-72chevytrucks.com/vboa...d.php?t=339280
  • Brackets $70.00
  • Rotors $107.98
  • Calipers $201.98 (includes core charges)
  • Pads $18.99 (semi-metalic)
  • Hoses $21.98
  • Banjo bolts $6.58
  • Total $433.09
Some additional figures to use for comparison purposes. Larger diameter piston means more pressure applied to the pads.
Caliper Piston diameters
  • D52 with JB5/6 designation 2.937"
  • D52 with JB7 designation 3.156
  • '94-'96 Impala ss 2.130"
  • '93-'97 F-body 1.590"
Old 07-10-2010, 04:17 PM   #33
mac72
Captain
will your d52 brackets,wilwood d52 calipers & '94/'96 Impala SS rotors work?
Mac
mac72 is offline   Reply With Quote
Old 07-10-2010, 11:27 PM   #34
Captainfab
60-66 Nut
No, you cannot use the Impala SS rotors with these brackets and the D52 calipers. These are designed to be used with the Astro van rotors which are much thicker than the Impala rotors, and will be the same size as your front rotors. Why do you want to use the Impala SS rotors when they are lighter duty and more expensive than the Astro van rotors?
Originally Posted by mac72 View Post
Captain
Mac
Old 07-11-2010, 02:26 AM   #35
mac72
Allready purchased front & rear crossdrilled rotors w/ wilwoods in the front.Had the impala calipers planned for the rear but would much rather use the wilwoods in the rear also.I know the astro rotors are thicker where the pads ride but How thk. are they at the axle compared to the impala ones,I dont have any more back space left w/ the wheels i'm using. Do you know if we can get them cross drilled & zinc plated?
Old 07-11-2010, 12:34 PM   #36
greystoke
Any plans to work something up for the rear of the 88-98 trucks?
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 07-11-2010, 10:37 PM   #37
Captainfab
60-66 Nut
The new Astro rotors that I have are .275" thick where they bolt up to the axle flanges. The Impala SS rotors are .245" thick, so only .030 thicker. A used set of Astro rotors that I have here have the stamped steel hat that is about .125" thick. However I don't know if that style is still available. Yes the Astro rotors are available cross drilled and zinc plated.
Old 07-11-2010, 10:40 PM   #38
Captainfab
60-66 Nut
I have been considering it since there have been a few inquiries about brackets for those rear ends. I need to post up over there and see how many guys are interested and in which style.
Old 07-12-2010, 11:10 PM   #39
texastrendz
can i get the d52 style mounts poweder coated in gloss black, or satin only?
texastrendz is offline   Reply With Quote
Old 07-12-2010, 11:17 PM   #40
texastrendz
nevermind, read your earlier posts. what is a lead time on the d52 with astro rotors powdercoated gloss black?
Old 07-13-2010, 12:19 AM   #41
Captainfab
60-66 Nut
I should be able to get that done within a week. Shipping time will be 2 to 3 business days.
Old 07-21-2010, 11:00 AM   #42
ERBSIX
ERBSIX's Avatar
CaptainFab, have you seen anyone combine your brake conversion kit
with an underdash pedal kit?
Like from Scott's Hotrods? (http://www.scottshotrods.com/UnderDashPedalAssembly.asp)
78 Silverado 1/2 Ton LWB (restore)
78 Silverado 3/4 Ton LWB (parts truck & practice - eventually a work horse)
My Build thread: http://67-72chevytrucks.com/vboard/s....php?p=4082128
Ellis Benus - Web Design Columbia Mo & Google Fan Boy!
ERBSIX is offline   Reply With Quote
Old 07-21-2010, 10:55 PM   #43
Captainfab
60-66 Nut
Not to my knowledge.......It wouldn't function any different than having the booster and master on the engine side of the firewall, as long as you have the correct components for a disc/disc system.
Old 07-22-2010, 11:16 PM   #44
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by joeelutz View Post
Were there any GM vehicles made that used a D52 style caliper on a rear disc brake with a drum style parking brake inside the rotor?
There is something close that can work with the D52 calipers as well as any other caliper designed for 1.25" thick rotors like the LS1 Camaro & C4/C5 Vette PBR front calipers. The 65-82 Corvette rear rotors are 11.75x1.25 and use a drum brake parking brake inside the rotors. Only down side is they are 5 on 4-3/4" bolt pattern but they can be drilled for a second 5 on 5 pattern to work on our trucks.
They fit with 15" rally wheels and you can get all the e-brake parts made from stainless steel from the Vette restoration places pretty cheap.
You can get the backing plate parts from a JL-8 optioned 4-wheel disc 69 Camaro application that fit up easier to a straight rear axle vs. the Vette parts designed for their IRS but the parts are pretty pricey. I have been tinkering around with some inexpensive ways of using the parking brake parts with a fabricated backing plate for the standard rear axle but haven't had the time to test it out and I don't have all the e-brake parts to make it functional.
NAPA sells the American made Vette rotors for under $40 too.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 07-22-2010, 11:55 PM   #45
68 TT
68 TT's Avatar
I have seen some newer AWD Astro vans with six lug wheels (the same wheels that came on my 03 Tahoe) so I am assuming they are a 2003 model year or so. Have you looked into using the D52 brackets with these rotors on a 4x4 application?
http://www.napaonline.com/Search/Det...+50014+2014004
They are 1.14" thick and 12" diameter so I don't know if the D52 caliper can handle that for sure. You would think that 1/10th of an inch smaller would be OK.
Old 07-23-2010, 01:22 AM   #46
Captainfab
60-66 Nut
I guess I haven't paid much attention to the newer Astros. I'll have to check into those and see what style of parts are used. I do already have something in mind for a 6 lug rear disc, but I'm reluctant as I'm not sure how well they would sell. Thanks for the info....
Old 07-26-2010, 12:03 PM   #47
68 TT
68 TT's Avatar
I will be your guinea pig on the 6-lug rear disc if you want.
My 67 is sitting on a square body 4x4 half ton chassis so it is 6-lug and I have a set of the El Dorado rear calipers.
I was thinking that the 88-98 new body style 4x4 slip on front rotors might work for this. I keep meaning to grab a set from Pull & Save to test out but always run out of time when I am out there. I will look them up on NAPA's site and get some idea of the offset and thickness to see if it is even worth picking up a set to test out.
Old 07-26-2010, 10:26 PM   #48
Captainfab
60-66 Nut
Yeah I was planning on using the '88-'98 K1500 rotors. I've already got the dimensions on them and the brackets will be this style, just a different spacer. I might see about ordering some spacers cut for these this week.
Old 07-27-2010, 11:59 AM   #49
68 TT
68 TT's Avatar
The rear rotors on my 03 Tahoe might be an option too if your wheels can clear 13" rotors. They have more rotor offset so they might push the caliper out of the wheel far enough to make them work with 15" wheels.
http://www.napaonline.com/Search/Det...50014+2014365#
Old 07-27-2010, 10:42 PM   #50
Captainfab
60-66 Nut
Yeah I've found similar ones from the Savanaha vans. The only problem with putting say a 13" rotor on the back is that you really should run one on the front as big or bigger. That is where it becomes a little more involved and $$. Those Tahoe rotors are really deep.....about 1/2" deeper than the Astro rotors.
