#26 |
![]() Join Date: Jul 2008
Re: want to cut springs have ???'s
I'd say around $50-$65 is reasonable. I had to get stock ones made at a shop locally. The receipt is gone now, but it was just a dollar or two shy of $60. It would probably be cheaper to do that than to get the nuts washers and bolts through lmc.
1965 c/10 swb 1969 c/10 lwb ![]() Last edited by chev-obsession; 05-04-2010 at 10:50 PM. |
#27 | |
Shake and Bake!
![]() Join Date: Feb 2010
I'd check to see if you have a Big Rig shop near you, I had a Big Rig alignment/spring shop make mine for $20.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
#28 |
Grandpa in the rustmobile...
we got some kinda shop locally (bfe) but they wanted 60+ lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#29 |
Shake and Bake!
Yeah, that's a little steep. Hopefully you can find a cheaper set.
#30 |
yeah i know its expensive but around here its considered reasonable being since thats the only place that could make them/have them. btw it was a driveline shop. everyone else recomended them.
1965 c/10 swb 1969 c/10 lwb ![]() |
#31 |
I ordered lowering springs online and cut a coil out of them. Thought the original ride was rough... I hate hitting bumps in my truck now. Really not worth it in my opinion. Your sacrificing alot of ride quality for a few inches lower. I mean it looks good, but like I said, every little bump gives me a headache
![]() 1968 C10 250 I6 |
#32 |
http://67-72chevytrucks.com/vboard/s...d.php?t=356615
check out the jeep wrangler thead I made it come back to life, may check into this, but id like some more info on how strong they are (can i still haul stuff in bed)
#33 |
i checked out the thread but never saw anything about what year wrangler springs i needed
1991 Camaro Z28 ![]() |
#34 |
The Wrangler springs look like the deal if you don't plan on hauling much of a load which most guys with custom trucks don't anyhow.
#35 |
Moderator
![]() Join Date: May 2007
I just got some Wrangler TJ springs off craigslist. Any year from 97-up. YJ Wranglers used leaf springs and were from 87-95. There was no Wrangler model in 96. After putting them in, they only lowered my truck by 1/4". Of course, there is no bed on my project at this time, so I can only assume the weight of the bed will compress them down. They are IDENTICAL in height to my factory springs, so it has to be the weight rating that is different. The coils are about half the diameter of the originals. I doubt you could haul much in the bed with them, other than a cooler full of beer (which is all I ever plan on hauling anyways).
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 05-12-2010 at 12:32 PM. |
#36 |
bought my jeep springs off craigs for $20, and cut one full coil from the front springs. it brought me down about 2" up front and about 3.5" in the back. you will not be able to haul anything heavy like a boat or u-haul trailer, but the ride is still very good.
#37 |
here is how it looks now
#38 |
![]() Join Date: Aug 2001
THE REAR COILS OFF OF A LATE 70s EL-CAMINO BOLT UP, & GIVE YOU 3 OR 4" OF DROP. NO PROBLEM CUTTING ONE COIL OFF THE FRONT. JUST MAKE SURE TO USE A CUTOFF WHEEL & DON'T GET EM HOT. FOR GODS SAKE.... DON'T CUT THE REAR COILS NO MATTER WHO SAYS IT'S O-K. IT'S NOT. & DON'T TAKE A TORCH TO EM EITHER. IF YOU WANT TO KILL YOURSELF... H@LL ... I WONT GET IN YOUR WAY, BUT THE PUBLIC ROADS ARE JUST FULL OF INNOCENT PEOPLE THAT MAY NOT WANT TO GO WITH YOU.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#39 | |
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 05-12-2010 at 06:15 PM. |
#40 |
Insert Title Here
8- 50lb bags of sand dropped my rear nicely
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
#41 |
Moderator
Cinder blocks work well too, and the added weight makes for a better ride.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#42 |
I started the process of installing the wrangler springs tonight, I just don't know if my shocks are goin to bottom out or not.. anyone had any issues with that, and if so maybe a hint at what size shockes I need to run
