Old 07-12-2010, 01:19 PM   #26
85burb
85burb's Avatar
Re: LSx Header options
Pacesetter does not have any....dang it!!
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 07-12-2010, 01:37 PM   #27
68 TT
Still plays with trucks
68 TT's Avatar
Why not take a set of Pacesetter long tube headers designed for a 99-up LS engined truck and modify them to fit our truck. Can't be too far off.
http://www.summitracing.com/parts/PSM-70-2265/
What about asking Pacesetter to make a set specifically for our trucks in both gen-1 small block, big block and LS transplant varieties? Couldn't hurt to ask.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 07-12-2010, 03:27 PM   #28
85burb
85burb's Avatar
I dont have the tools or time to do that. Wish i did. Am trying to find direct drop in. If i cant i will just use stock manifolds tell i can get a set and make them work.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-12-2010, 04:11 PM   #29
SatisTraction
i put a set of hooker 67-69 camaro swap headers on my 85. the drivers side took a litttle grinding on the motor mount. about 5 minutes of work.
On the passenger side i had moved the mount for the "fred" mod and had to do a little more work over there. i cut about 1/2" off the top of the frame and did some grinding on the mount. I think the mount could be moved forward and do little to no grinding.
WTB 73-87 SWB fleetside bed!!
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
75 bronco injected 351w
SatisTraction is offline   Reply With Quote
Old 07-12-2010, 06:20 PM   #30
85burb
85burb's Avatar
Any pics. What mounts did you use?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-13-2010, 03:18 PM   #31
SatisTraction
i can try to get some. i used carshop plates.
it WAS NOT a bolt in but it was not too much work and i did not have to modify the headers.
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
Old 07-14-2010, 07:51 PM   #32
85burb
85burb's Avatar
May have found a set of long tubes that will work. They are for 98-02 camaro. A little bit of frame trimming is need but not too much. Best of all they are 170 a set.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-15-2010, 11:36 AM   #33
68 TT
68 TT's Avatar
Got a link to where you found those?
Old 07-15-2010, 09:43 PM   #34
85burb
85burb's Avatar
The truck that i got idea from
http://67-72chevytrucks.com/vboard/s...d.php?t=411567
The company i may get mine from.
http://cgi.ebay.com/ebaymotors/98-02...Q5fAccessories
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-16-2010, 11:22 AM   #35
68 TT
68 TT's Avatar
I don't care where they are made, that is an amazing deal on a set of 1-3/4" tube stainless long tube headers. Looks like they have 3/8" thick flanges too. I am going to have to give them a try.
Thanks for the links.
Old 07-16-2010, 12:02 PM   #36
MONTEZ
My bet would be that the flanges are not made of the same material as the tubing. If this is the case, those tig welds will start cracking in about a year. Been down that road on my DSM before. I figured hey it's cheap and I bet it's pretty much the same. WRONG, one year and 13 weld fixes later I decided to break down and by a more expensive one. Replaced it with a DNP tubualr manifold, bout $700 for a four banger exhaust mani, never had anymore issues. But too, this was on a forced induction engine runninng 26 psi boost.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 07-16-2010, 12:33 PM   #37
68 TT
68 TT's Avatar
I had the same problem with the factory headers on my 86 Grand National. I welded those pigs back together at least a dozen times before I broke down and built my own out of heavy wall tubing with thicker flanges.
Thin wall stainless tubing and the heat of forced induction do not mix well. I worked on fighter aircraft for 13 years and had to fix countless heat stress cracks in stainless.
It just needs to be thicker in high heat areas like a turbo header. Using schedule-40 stainless pipe instead is the way to go. For a naturally aspirated engine the heat load (if it is jetted right) is far less and will most likely never make the headers hot enough to damage the welds.
The flanges look to be stainless at least and 304 is one of the least expensive ones to use so I would bet they used the same 304 on the flanges. You can weld mild steel to stainless but the flanges are too shiny to be mild steel. You can polish it up but it doesn't look the same as stainless.
Old 07-16-2010, 12:48 PM   #38
MONTEZ
Hard to tell in the pictures. Mine was supposed to be all stainless according to the add, but they were stainless tubing on chrome plated mild steel.
Old 07-16-2010, 01:21 PM   #39
85burb
85burb's Avatar
We will deff find out. Maybe by the time they crack someone will have a swap header out.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 09-03-2010, 08:34 PM   #40
85burb
85burb's Avatar
Does any one know of any one that put out headers for 73-87 truck swap headers yet?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-13-2010, 09:22 PM   #41
85burb
85burb's Avatar
Got my headers in mail today. They look great for what i payed. The box was tore up from shipping and one of the collectors was a tiny bit bent like Fedex therw it down stairs. It is just barly noticeable. Will be welding a flange on them anyway so not a big deal at all. Deff hope they fit good cause they look great.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-13-2010, 10:48 PM   #42
Magnimike1
well keep us informed
Magnimike1 is offline   Reply With Quote
Old 10-14-2010, 07:58 AM   #43
silvereagle07
silvereagle07's Avatar
They look nice. Let us know how they fit.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 10-14-2010, 11:21 AM   #44
68 TT
68 TT's Avatar
Look pretty good for the money.
Hard to tell in the pics but it looks like that weld at the flange is discolored like it should be so the flanges are probably stainless like they said. You can't weld to chrome so if it was plated steel they would have had to plate over the welds to completely chrome plate the flanges. Doesn't look like they did that.
You might have to relocate that oxygen sensor fitting but that would be good as I don't think that position has a good enough angle to it so the moisture drains out of the sensor easily. Probably easier to leave that one there and put a new fitting where it works for the Suburban.
Old 10-14-2010, 04:48 PM   #45
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Seems like alot of work when we all know the quality and fit of the S&P headers. Maybe we could do a group buy and get a discount? Just my opinion though.
--Josh
Old 10-14-2010, 09:25 PM   #46
85burb
85burb's Avatar
I just cant see paying 600 bucks for some at best mid length headers. I will not have 02 sensors. Will be using a carb. I will inform yall on the fitment. For the money i am very happy. I will just be using them to see if they fit. If they do i will buy a good set after these fall apart.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
