LSx Header options
Ok what header do you have on your 73-87 truck. I only know of one company that has them. S&P. But i dont really like the length and collector and they are close to 600 bucks shipped. Where else sells them that will fit? Looking for long tube but dont think any will be made. Dougs was making some but have not heard any thing from them. Or what maniflods fit with no fram cutting.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
Re: LSx Header options
98-02 fbody manifolds work, grind a little bit on pass side manifold and good to go.
I heard pacesetter fbody longtubes work...
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I hear Doug Thorely makes a long tube for these swaps also, if I remember right, you can pick them up under $500.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
They dont have one out for 73-87 yet. pretty much everything else they have them tho. I think people have tried to put the 67-72 on the newer ones and they did not work. Shon that sells them says they dont fit and he does not have an answer for if and when they will come out.
I had a set of thorleys, and I can tell you they DO NOT fit.
What did you go with then?
Does Muscle Rods not offer any?
I have a set of stock manifolds from my lq4. I'm not gonna use them. You can have them if you want em. Also if you know of anyone looking for any ls parts I have a fully loaded cathedral port manifold, and the stock harness and controller. Cheap.
Smoke Tires, not Drugs Last edited by MONTEZ; 07-08-2010 at 09:31 PM. |
Have not heard of them yet. I am also trying to sell off my maniflod. Not even one hit on this web sight. I my have to take you up on the maniflods i ony have one. I am hopeing to find headers.
http://www.brphotrods.com/mm5/mercha...Store_Code=BRP
Check there. www.mastmotorsports.com in nacogdoches is a muscle rods dealer. If you order anything thru them I can bring it to you next time I come to Tyler (at least every other weekend). Also they can tell you about any kind of manifold you are in the market for. Very knowledgeable guys. If you call ask for Brian, Nathan or Horace. Horace is the owner and can tell you anything about Ls engines. But he left town today and wont be back for 2 weeks. Have you ever looked into to Lonestar racing on 110 in Tyler across from Trane?
Smoke Tires, not Drugs |
Will have to call mast have not ben able to find anything on there web sight. Never heard of the one on 110.
Lonestar is pretty good and you'd be surprised what they have in stock there. I think they are also RCI and Harwood dealers since they are both local to Tyler too.
Do they have web sight?
#13 |
#14 |
Thanks i will have to check them out.
#15 | |
Still plays with trucks
You can always modify a set of big block headers to fit using new LS flanges from GMPP or other sources. The third gen F-body guys have been doing this for quite a while.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#16 |
I have been trying to get some info on this as well. I heard gto or chevelle swap headers will work but have'nt confirmed this. Gona do a carbed 404 dont want to choke it w/manifolds or waste some tq w shorties. Looks like its going in my chevy 2 then.
#17 |
That is my prob. Lots of people say they may work but i cant spend my hard earned money on may fit. Wish the header companys would get off there kister and start fabing stuff up. Every one makes them for older and some newer truck just not our year. Just like the 4 wheeling croud evrything for jeeps is made but nothing new and exciting for our stuff even tho they do just as good as them jeeps. Sorry just venting have been looking for 6 mounths and found 1 that def will fit. Thanks for idea tho.
#18 |
I have the s&p headers
#19 |
How do they fit? I read someones build that they sent wrong ones then the ones they sent back to get them to work they had to cut ear off of transmission. I really dont want to pay 600 bucks for a set but i guess if that is my only option i may have too.
#20 |
that was me. I cut the ear off and sent them back. Cutting the ear of is no big deal.
S&P sent the correct ones for a 4l80e.
#21 |
I dont want to cut mine it has worrenty still. Will they be a problem with a 700r4?
#22 |
no, just make sure you tell them what tranny you have and they will make the headers to fit, no problem.
#23 |
Is that the only option you know of?
#24 |
Have you checked pacesetter?
#25 |
They dont show them online. Will have to call them.
| Bookmarks |
