Old 11-11-2010, 12:59 AM   #26
lurch115
lurch115's Avatar
Re: D44 Steering Arm
My alternator went bad after I put a lift kit on,too.I think it's from all the hammering.
Glad to hear you whooped that bear.I used to go right out and lift my old 4wds first thing.I came around to realize if you can't do it all at once (because of money),you should first get everything tight in the front end/steering,then install lift.That leaves no "round tuit" factor and you really need a tight front end with a taller truck with bigger tires."Do it right or don't do it at all".Nothing beats those first miles at the new altitude.Feels best after you did it all yourself.A feeling well earned.
i think the alternators go bad from the change in elevation. had the one on the "skytation go bad after i did the axle swap and it gained a few inches.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
