#26 |
Re: Lets see that exhaust!
For God so loved the world that He gave His one and only Son to who ever believed shall not perish but have eternal life. Red 8T3
![]() 10/2/10 2/29/12 Gracie-Jo PAK-MAN. |
#27 |
sweet i was just curious i hear alot about flow and angle of bends hindering power. I bet that has some serious throat to it
"Buckle up I wanna try somethin!!" "of course it will hold!, I welded it!" 1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint |
#28 |
oh yea it thumps good , good size cam Comp Xtreme enrgy 294 int 306 exh, heres a small clip I got of it in the garage not real good I may get it out today it over 50 in NE Ohio !
#29 | |
What all have you done to your motor? I am building a 468 for my half ton. I would love to see what all you have done. Posted via Mobile Device |
#30 |
I've only had the original 40 series in my trucks and i like how they sound, i haven't tried anything else. My 454 sbc had headman headers with 3'' pipe turned out before the wheels with the mufflers almost right under the cab. It was a little too loud. Now im gonna go with 2.5'' and turndowns right before the diff and see how that sounds.
#31 |
thanks, no problem heres a quick run down , I started with a .060 over 454 block,changed the rotating assembly with a 4.25" stoke crank , .250" longer rods and keith black #kb284 9.5:1 pistons, the cam is a Comp # CL11-254-4 , I had a set of 781 heads on it first with 2.250 intakes fully ported and shaved it ran great , but I bought a set of gm performance aluminum oval ports (same head that the zz502 has) changed the springs out for the comp cam # 930 springs that were for the cam, push rods are .100" long with roller rockers,I smoothed the ports out a bit and stuck them on ,the intake is a edelbrock airgap with a 850 vacuum sec holley , I was just goin to refesh the old stock 454 but my boss said how bout ya build a stroker about 30 times , he put a zz502 in his 72 chevy and I didnt have the funds for that so this is the way I went , its a bit much for everyday drivin but should make a great cruiser
| Bookmarks |
