Old 05-18-2012, 11:10 PM   #26
v30crewcab
v30crewcab's Avatar
Re: '84 k30 cummins swap build pics
Oh yea, how did you make your engine cover? thats sweet. need to do something like that on my motor.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 08-17-2012, 11:25 PM   #27
Krwright
Cab finally done starting to look like something. Exhaust half done. boost tubes done.
i do my burn outs in 4wd
Krwright is offline   Reply With Quote
Old 08-17-2012, 11:27 PM   #28
Krwright
I ground the dodge letters off. Then just used filler over it and had the local sign maker cut me a decal.
Old 08-17-2012, 11:29 PM   #29
Krwright
http://s1070.photobucket.com/albums/u493/krwright0313/
Old 08-25-2012, 04:56 PM   #30
Krwright
Working on the radiator and fan. The rad will be here Monday I was planning on running dual 14" electric fans in between the inter cooler and radiator. But I'm thinking I might get lucky and use a stock fan and clutch. I don't have the original cummins hub it was busted and trashed but does anyone know the total thickness of the entire assembly??
Old 12-09-2012, 03:10 AM   #31
DBear
DBear's Avatar
did you use the PATC mounts? If so, what do you think of them? How is the fitment of the motor in the engine bay/ firewall? thanks for any help you can provide.
DBear is offline   Reply With Quote
Old 12-09-2012, 01:17 PM   #32
Krwright
Yea patc mounts. Great fit. I answered your pm. Give me a shout. I have some more pics ill upload.
Old 12-15-2012, 01:00 PM   #33
Krwright
Put up a few more pics John hope it helps.
Old 12-18-2012, 12:10 PM   #34
DBear
DBear's Avatar
thanks for posting more pics buddy. Talk to you soon
Tommy
Old 03-17-2014, 01:36 PM   #35
Krwright
After taking almost a year off I'm finally getting back to finish this truck. Lift, rear disc, Yukon axles, drive shafts made, 1410 yokes throughout, painless harness, mile maker hubs, rebuilt front & rear diffs. Just a few more wires to run and truck will be done. Then time to tackle the rest of the body panels.
