Old 05-16-2012, 12:37 AM   #1
Krwright
'84 k30 cummins swap build pics
still have a long way to go.....
Krwright is offline   Reply With Quote
Old 05-16-2012, 12:38 AM   #2
Krwright
Re: '84 k30 cummins swap build pics
http://s1070.photobucket.com/albums/u493/krwright0313/
Old 05-16-2012, 02:37 AM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice swap and welcome to the truck board!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-16-2012, 07:12 AM   #4
andrewmp6
Looks good so far did you make that engine crossmember ?
andrewmp6 is offline   Reply With Quote
Old 05-16-2012, 07:29 AM   #5
Krwright
Yea I made it.
i do my burn outs in 4wd
Old 05-16-2012, 08:43 AM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Copy the crossmember and sell it!! You can make some nice $$$$.
Nice work!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-16-2012, 08:53 AM   #7
86c20
86c20's Avatar
i like the rocker cover. where did you get it or did you make that as well?
86c20 is offline   Reply With Quote
Old 05-16-2012, 10:04 AM   #8
Krwright
I made the over too
Old 05-16-2012, 10:12 AM   #9
Krwright
Nice work!!
Thanks. I found a cross member from a company making swap kits ( avalanche engineering i think)they wanted 800$!!!! They sent me a pic and it's just a piece 3/16 plate with 2 bends!! That's nothing but pure taking advantage of people. I made this for 17$.
Old 05-16-2012, 09:14 PM   #10
andrewmp6
avalanche engineering went under there is two more places that make one but not as pricey as they was.
Old 05-17-2012, 01:14 AM   #11
Dieselwrencher
Auto world has a nice cross member for these trucks. Way nicer than the avalanche one by far.
Ryan
Old 05-17-2012, 04:46 AM   #12
andrewmp6
Yeah i like auto world one too other option is http://www.tndieselpower.com/site/pr...ember-package/
Old 05-17-2012, 09:01 AM   #13
Krwright
I used autoworld mounts. That's not a bad price for the mount and member kit. I believe my mounts were around 300$. But I made a template for next time.
Old 05-17-2012, 03:00 PM   #14
Dieselwrencher
I build my own brackets but use auto world's poly mounts. Do you plan to do anything to the engine while it's out? KDP fixed?
Ryan
Old 05-17-2012, 03:08 PM   #15
Krwright
I bought the whole truck that was totaled. The motor has a ton of stuff done to it injectors, pump work, delivery valves, hybrid turbo, head studs, cam, timing, flywheel, low stall converter, tranny valve body and shafts. It made several ponies in his truck and would honestly black out both lanes of the interstate. The kdp struck him a few years ago.
Old 05-17-2012, 03:14 PM   #16
boatpuller
boatpuller's Avatar
you may have posted...but,i didn't see it..........what cummins is that ?
looks good so far
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 05-17-2012, 03:35 PM   #17
Krwright
I'm fitting the intercooler today did u use the dodge? That's what I'm doing and it fits pretty sweet when I flip it upside down and not much cutting. Did u leave the brace out for the hood latch? It's weak as hell without it but nowhere to mount it with the cooler in the way
Old 05-17-2012, 03:42 PM   #18
Krwright
It's a p pump
Old 05-17-2012, 10:11 PM   #19
yousesteers
I flipped my intercooler upside down. I also left the bracket and the safety latch out.
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 05-18-2012, 10:14 PM   #20
Krwright
Got the intercooler mounted today. I have an Idea I want to run by everybody. I have 2 3/4 inches between the radiator and intercooler. If I mount the fan in front of the radiator and wire it to push will it still draw enough air for the intercooler? I'm keeping the engine compartment as clean as possible by hiding everything wiring, batteries etc. just thought that would be great to even hide the fan.
Old 05-18-2012, 10:35 PM   #21
Dieselwrencher
It could but I generally mount them on the engine side so the fans don't over heat. Usually there isn't room to mount them in front. By the way, where you have that breather on your vacuum pump is actually your outlet for the vacumm accessories.
Ryan
Old 05-18-2012, 10:39 PM   #22
Krwright
Yea I know I'm not running any vacuum on anything. Using hydro boost. Didn't know what else to put on it to keep the dirt out.
Old 05-18-2012, 10:41 PM   #23
Dieselwrencher
Are any of your a/c controls vacuum? Or does your truck have no a/c?
Ryan
Old 05-18-2012, 10:43 PM   #24
Krwright
No a/c.
Old 05-18-2012, 11:06 PM   #25
v30crewcab
v30crewcab's Avatar
I just got done cutting the supports on the inside of the core support out, so the intercooler is now sitting in there, right in front of the radiator. that way I don't have to trim the grille this time.
only thing I would do different on the crossmember is make it removeable from the bottom. I didnt' on my last one, and had to cut it in two to get the oilpan off, so its getting rebuilt differently this time around.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
