Old 09-05-2012, 09:21 AM   #26
DevilDog Aggie
DevilDog Aggie's Avatar
Re: Newbie Here - My first project - Reveille!
Originally Posted by JRANGER View Post
that brake booster sure is pretty
:-) Thanks!!!!
Rob
'72 Chevy C-10 - 350-5.7/TH350/PS/PB/AC
Build Thread - http://67-72chevytrucks.com/vboard/s...87#post5503187
Semper Fi and Gig'em Aggies!
DevilDog Aggie is offline   Reply With Quote
Old 09-15-2012, 04:50 PM   #27
DevilDog Aggie
WTF!!!! Coming home from getting her inspected this happened! Any lines on some inexpensive exhaust manifolds????
Rob
Old 09-15-2012, 05:07 PM   #28
Low Elco
Search online. Dorman makes them. Sorry!
Low Elco is offline   Reply With Quote
Old 09-15-2012, 11:28 PM   #29
Tinkermc
at least it was after inspection, noe you only need 2 fix it b-4 you drive it.
Tinkermc is offline   Reply With Quote
Old 09-16-2012, 12:24 AM   #30
JRANGER
JRANGER's Avatar
wow thats crazy
JRANGER is offline   Reply With Quote
Old 09-16-2012, 01:47 AM   #31
Xeen
Xeen's Avatar
You can probably find a set of rams horns localy if you live near a major city.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-17-2012, 04:44 PM   #32
DevilDog Aggie
Thanks guys. Found some Dorman's for 55/each. I know what I am doing this weekend! That and replacing the intake manifold gasket. :-)
Rob
Old 09-17-2012, 05:32 PM   #33
Low Elco
When you change them- go to AZ and get Percy's copper gaskets, and permatex Ultra Copper. Slather your donut gasket in the copper rtv. Crank it all down and have a couple slow Shiners before firing it up. Drive 'er around a few times and crank it down again. Voila'! Quiet truck for the long term! Congrats on the inspection, now go do some burnouts and piss off the HOA!
Old 09-17-2012, 06:43 PM   #34
19Chevy67C10
19Chevy67C10's Avatar
Talking Re: Newbie Here - My first project - Reveille!
Originally Posted by DevilDog Aggie View Post
Got the brakes replaced and bled. Even after getting a notice from the local PD that someone complained because she was on stands for a day. Really? Anyway, still having brake issues. Have ordered a new booster and master cylinder which should be in tomorrow. Having issues with the parking brake too. It won't hold. Pulled the rear wheels/drums off last night to inspect and did find a few pieces that may have slipped while I was installing. Fixed those but same issue. Cables pull the lever, but apparently aren't pulling tight enough. I'm going to go through the cables this weekend and tighten where I can. Any other thoughts?
Really want to get her inspected and at least road worthy. Also have to adjust the timing. She diesels after shutdown. I have done a full tune/carb replacement. Before that she wouldn't even hardly start. So I am pretty sure I got that part right. Thinking about running a can or two of seafoam through her to see if that helps as well to break up any buildup in the intake.
The truck was called in by another jealous 72 chevy truck owner with an rust bucket! lol
Kev's-C-10
19Chevy67C10 is offline   Reply With Quote
Old 09-18-2012, 07:44 AM   #35
DevilDog Aggie
LMAO!!!! Probably so!!!
Rob
Old 09-18-2012, 07:46 AM   #36
DevilDog Aggie
Thanks Low!!! There will definitely be some Shiner's killed during the process!
Figure while I'm at it, I'll go ahead and replace the valve cover gaskets too! Might as well make a day of it!
Rob
Old 09-19-2012, 09:46 AM   #37
DevilDog Aggie
Well, thought I would be replacing exhaust manifolds, intake gasket and valve cover gaskets this weekend. Unfortunately my daughters '96 jeep GC's water pump is going out. So that is what I will be doing this weekend! Dang it!!!!!!
Rob
Old 09-19-2012, 10:01 AM   #38
Low Elco
If its a 6, it's a couple hour job. Have fun with the rad and grille. A dewalt heavy drill and a 10 mm socket is your new best friend. Pump itself is pretty quick and easy.
Old 09-19-2012, 10:54 AM   #39
DevilDog Aggie
Thanks Low! Yep it is the inline 6. Still may work on Reveille this weekend if I can. Hate to leave her alone! :-)
Rob
Old 09-19-2012, 09:26 PM   #40
Tinkermc
glad you found the part so quickly
Old 09-20-2012, 06:59 AM   #41
Low Elco
Doh! I forgot, the one I did had a balancer as part of the job. You shouldn't have to pull the grille, water pump was cake.
Old 09-20-2012, 07:01 AM   #42
Low Elco
Also, check into the Neon fuel injector upgrade. Better mileage, smooth running and easy to do.
Old 09-22-2012, 02:22 PM   #43
DevilDog Aggie
Daughters jeep is done. New water pump, hoses, clutch etc.... Starting back on Reveille's exhaust manifolds. Have I mentioned I hate Metric based cars!!!!!!
Rob
Old 09-22-2012, 02:29 PM   #44
DevilDog Aggie
Old drivers side EM and new one! BTW, I picked up a drivers side ram horn at a scrap yard yesterday. Paid 60.00 for it, if anyone interested let me know.
Rob
Old 09-22-2012, 02:30 PM   #45
DevilDog Aggie
apparently my phone takes too big pics. I'll get them up tonight. Plus the one for sale.
Rob
Old 09-23-2012, 03:52 PM   #46
Tinkermc
glad 4 you that Jeeep was so easy
Old 09-24-2012, 09:29 AM   #47
DevilDog Aggie
Thanks Tinker! Apparently something happened with it this morning on the way to school. She got to school and said it was smoking and AF was pouring out. It is only a 2 mile drive to school so I can't imagine what happened. It was driven all weekend with no issues. :-( Gonna have to try to get off work early and go see I guess.
Rob
Old 09-24-2012, 09:35 AM   #48
DevilDog Aggie
Here are the pics. Had to grind off one of the studs going to the exhaust on the drivers side. Then on the passenger side, had to grind off two of the manifold bolt heads. They had been rounded off and wouldn't come out. Got it put back together but need to go to hardware store and pick up a couple of bolts to finish putting it together. :-(
Rob
Old 09-24-2012, 10:25 AM   #49
Low Elco
Ah, the eternal question- how can a man drive a vehicle for days no problem, and a woman drive it for ten minutes and kill it? How? Glad you got the truck runnin! Give it to the daughter so you'll have to put a 450 horse 383 in it! See- I'm an innovator!
Old 09-24-2012, 11:59 AM   #50
DevilDog Aggie
Originally Posted by low elco View Post
ah, the eternal question- how can a man drive a vehicle for days no problem, and a woman drive it for ten minutes and kill it? How? Glad you got the truck runnin! Give it to the daughter so you'll have to put a 450 horse 383 in it! See- i'm an innovator!
posted via mobile device
lmao!!!!
Rob
