Old 10-19-2012, 09:09 PM   #26
clinebarger
Re: What year motor?
Verifying the VIN of the vehicle that the engine came from is the easiest way.
8th vin digit U.....LQ4.
8th vin digit N.....LQ9.
Ive had wreaking yards try to pass off LQ4's as LQ9's.
I made a jumper/patch harness (PCM plugs with power, ground & data link connector) & use my Tech 2 to read the VIN thats in the PCM.
clinebarger is offline   Reply With Quote
Old 10-20-2012, 09:49 AM   #27
ls1nova71
ls1nova71's Avatar
Originally Posted by BR3W CITY View Post
Source on this? When I was sourcing my pcm, my tuner informed me that for my swap (dbw 6l/4l80e, 2003/04) I had to get a v8/auto pcm, because the manual trans pcm had problems with the second vss sensor input from the 4l80e.
The 411 PCM will work on almost every DBC application... basically 99-02 LS1s and truck engines. It also has the ability to run DBW. Having it run a 4l80e would require a segment swap that most tuning software isn't capable of. Also it wont work with the 03-up TAC. But for a standard DBC setup they're fine. I'm running one in my '33 with an LS1 that came out of an Astro van.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-20-2012, 02:30 PM   #28
Wasted Income
Boosted Member
Wasted Income's Avatar
I use EFI Live to do the segment swap to go to 80e or manual trans, and I've always had good luck interchanging pcms from V6 trucks/vans to other LS vehicles.
Painter, I've recently acquired another spare 0411/DBC TB/harness. PM me if interested.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-29-2012, 10:18 PM   #29
Painter D
Painter D's Avatar
Alright got another question.
The trans. I got came out of a truck its a 4l60e does it matter what year it is? The Escalade my motor came out of was AWD that's why I didn't get the trans. out of it.
Also, I don't see any way to access the torque converter bolts am I not seeing something?...............Forgive my lack of LS experience
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 10-29-2012, 10:48 PM   #30
ls1nova71
ls1nova71's Avatar
It matters to an extent, but as long as it's a '99 up you shiould be ok. Do you know what year it is? And to access the torq converter bolts you have to take the starter off and the plastic shield behind it.
Old 10-29-2012, 10:55 PM   #31
Painter D
Painter D's Avatar
Thanks, I'm pretty sure the trans. Is 03 or 04
Old 10-31-2012, 06:25 PM   #32
Painter D
Painter D's Avatar
I was wrong I looked it up and the trans. is a 2000, it should still work fine .....right?
Old 11-01-2012, 10:43 PM   #33
ls1nova71
ls1nova71's Avatar
Yes.
Old 11-01-2012, 11:32 PM   #34
clinebarger
There are 298mm & 300mm versions, 4.3 & 5.7 Vortec's have 298mm 4L60E's
All LS based engines with a 4L60E use the 300mm version.
Old 11-02-2012, 12:10 AM   #35
ls1nova71
ls1nova71's Avatar
Doh! I was thinking V8 2000 pick up when he said it was a 2000. I didn't think about a V6 truck, or the possibility it came out of a van.
Old 11-02-2012, 02:59 PM   #36
Painter D
Painter D's Avatar
So what does that mean? Is it good ,bad, or does it even matter?
Old 11-02-2012, 09:06 PM   #37
clinebarger
Pull the converter, Check the input shaft.
ID info....
Old 01-23-2013, 06:53 PM   #38
solidaxel
solidaxel's Avatar
Thanks found the info on page 6!!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
