Old 04-17-2013, 09:09 AM   #26
lmdangerous
Re: turbos on inline 6
Easy fix the- 307 chevy v8 piston can be picked up cheap ( in a forged piston-usually trw , sealed power etc) for the 250 -it is literally a drop in-pin height, rings , etc. On the 230 the 283 forged piston is a drop in . There are ten million sets of 283 pistons( forged and other on ebay etc.
It is true that some of the SBC pistons have a narrow skirt that will put some cylinder wall stress, but below 5500rpm its not likely to cause a problem.
I actually ran a set in a 250 with a supercharger- turned it 6500-7500 hard and often-ran 10-16 psi - with a 144 B and M blower on my intake - broke a lot of things - the pistons were not one of them.
I race on a shoe string budget-you lern to use a mic and read the part book fast. your machinist is your friend.
lmdangerous is offline   Reply With Quote
Old 04-17-2013, 12:04 PM   #27
Midgets50
Midgets50's Avatar
I doubt most of us actually will get the engines over 5500 rpm thats fairly high especially for a 6 cylinder
Midgets50 is offline   Reply With Quote
Old 04-17-2013, 12:22 PM   #28
mknittle
mknittle's Avatar
Thanks, I was thinking there might be another piston that would work.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-17-2013, 01:13 PM   #29
1-ton of fun
polishing a turd
1-ton of fun's Avatar
well, a 235 has a 3.562" bore correct?
ford modular engines have a stock bore of 3.552"
that's close and with some machining you might be able to use some over-sized forged pistons for a modular ford motor. there is still the pin diameter to deal with, but that's one idea. pins are only slightly larger on the ford pistons.
if a 0.030" over bore cleans up the bores enough, you could go with something like this:
http://www.summitracing.com/search/d...re-in/3-592-in
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 04-17-2013, 02:17 PM   #30
mknittle
mknittle's Avatar
So a .02 modular piston would be .01 over stock 235 Hmmmm
They aren't cheap though.
then there is the issue of only having four main bearings vs the 250 and 292 having 7
Mark
My GMC build.
Old 04-18-2013, 10:14 AM   #31
1-ton of fun
polishing a turd
Yeah and you obviously would need to convert to a full flow oil filter.
Old 04-18-2013, 10:16 AM   #32
1-ton of fun
polishing a turd
Yeah, it's too bad that I have a good set of forged modular pistons in my garage, but they are the stock bore size 3.552"
Old 04-19-2013, 12:15 AM   #33
1project2many
What's the pin height on the Ford piston?
1project2many is offline   Reply With Quote
Old 04-19-2013, 09:12 AM   #34
lmdangerous
Didnt Tom Langdon do a build on a 235 or a 261 that used either the 231 buick turbo piston or something GM. Check Toms site or the inliners international site. I bet some one has got it.
I always built the 250- 292 stuff becuase ituses half of the SBC parts and i can score them used for cheap.
LMD
Old 04-19-2013, 11:53 AM   #35
mknittle
mknittle's Avatar
That figures
Mark
My GMC build.
Old 04-19-2013, 09:58 PM   #36
72smoker
72smoker's Avatar
there is a thread started on this same topic on the 67-72 side as well. Too bad we can't get together on this.
72smoker is offline   Reply With Quote
Old 04-19-2013, 11:59 PM   #37
1-ton of fun
polishing a turd
1.1215" I believe
