Old 08-25-2013, 03:37 PM   #26
Redleg87
Re: 72 c10 engine position
Haha great.. yes runs fine. I suppose I'll leave it and clean up the welds.. putting a 4 speed in it this week. Was just kinda freaked.. never seen one back that far...
Redleg87 is offline   Reply With Quote
Old 08-25-2013, 03:40 PM   #27
Redleg87
Can I remove this for more access.. leave it off? Cover it with sheet metal?
Old 08-25-2013, 04:01 PM   #28
patdaly
Not unless you don't like heat and defrost........... Or put in an aftermarket HVAC unit.
patdaly is offline   Reply With Quote
Old 08-25-2013, 04:09 PM   #29
Redleg87
Gotcha.. I'll search around for one. Again. Really appreciate it.. was kinda freaking about it being close.
Old 08-25-2013, 05:02 PM   #30
fp1967
fp1967's Avatar
I agree with the others when they say to leave it there (as long as everything is working fine). On the 67-72 4WDs, the engines sit way back similar to the way yours does.
fp1967 is offline   Reply With Quote
Old 08-25-2013, 05:22 PM   #31
54belair
54belair's Avatar
Originally Posted by Redleg87 View Post
I just moved and don't have a set up garage yet. So taking to mechanic.. he's gonna fix that b.s weld... will it be okay to stay in the position its in?
My 68 was originally an I6. Years ago, when it was changed to an 8, they used the rear two mounting holes which is the original location for a 6. An 8 will work (as far as location goes) in the rear holes. However, with that said, the original location for an 8 Was in the two forward holes on the frame.
As previously mentioned, it will matter which trans youre going to use. In my case, I switched from an auto to a car 4 speed and had to relocate the trans crossmember anyway--so I wasnt worried about where the crossmember was originally.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 08-25-2013, 05:55 PM   #32
Redleg87
Mine has a 3 speed man in it now, switching to a 4 speed Monday.. so I should be fine right?
Old 08-25-2013, 07:20 PM   #33
Redleg87
So I can't remove the box and leave the plumbing and heater core connected? And still have heat?
Old 08-25-2013, 07:52 PM   #34
68gmsee
Active Member
68gmsee's Avatar
No. As mentioned above, unless you don't want heat in winter you can remove all that stuff and put a plate that they sell to cover the hole. You would have to go with aftermarket stuff.
Pic on link below.
http://67-72chevytrucks.com/vboard/s...d.php?t=367522
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-25-2013, 08:49 PM   #35
Redleg87
gotcha... appreciate it!
Old 08-26-2013, 08:38 PM   #36
Redleg87
UPDATE! Neighbor left new motor mounts on my porch as a gift and his brother that owns the shop is making a new cross member and installing my Muncie!!! Engine will be a ton easier to work on.. so blessed to have cool neighbors.
