01-23-2016, 04:01 PM | #26 |
78K & 79C Jimmys
Re: CB Radio question
Some of the unit when I got,The CB guts are in the second box.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-29-2016, 01:42 PM | #27 |
Any opinions on which of these simple models would be the best option?
found this handled one that converts: Amazon.com: Midland 75-822 40 Channel CB-Way... or this mountable one: Amazon.com: Uniden 40-Channel CB Radio... Also both of these look like they could plug into the cigarette lighter and work. The mountable one needs a converter to do that. Does that mean I would just plug it into the lighter, connect to the antenna and be ready to go>?
Thank you, Doc 1973 Cheyenne "I get up in the morning looking for an adventure." |
01-29-2016, 02:13 PM | #28 |
I wouldn't power it through the cig lighter if you don't have to.
Just wire it up to the fuse panel, crimp some of those cheapo speaker connectors to the wiring of the CB. |
01-29-2016, 06:55 PM | #29 |
Sounds good. I'll look into doing that. I'm sure there some online tutorials.
02-05-2016, 01:22 PM | #30 |
Anyone have a strong opinion on antennas? I was looking at the 4-5' fiberglass Fire Stick and a stake hole mount, or a wilson/cobra magnetic mount and finally a 102" whip with ball joint and tie down. I've heard the 102 can have high swr while driving because it bends.
This is a weekend warrior, hunting truck, so I was considering the magnet so I can pull it off when I'm not using it. Thoughts?
02-05-2016, 01:26 PM | #31 |
Also where do people run the coax, window seals, drain plugs, drill new holes?
02-08-2016, 09:32 PM | #32 |
^^^bump
02-08-2016, 10:35 PM | #33 |
Here's my setup. 1976 Midland 23 Channel. 2 3' Firestik FS-4 Tunable tip antennas. Mounted to the front of my toolbox. 18' Coax run between the bed and cab, along the frame rail, and around the front of the cab through the firewall. The extra is coiled in a figure 8 under the dash since I've heard you can get interference if it's just a single coil. I honestly haven't had a chance to test the range on it yet since I don't drive it on the salty Minnesota roads. I would have 4' antennas if I had the clearance for them in my garage. If I were you, I'd go with a single 4-5' Firestik antenna and tune it correctly
Dad's: 1973 Chevy C-60 Grain Truck 366 Big Block Dad's: 1982 Chevy Silverado 6.2L Diesel K-10 Dad's: 1987 Chevy Silverado TBI 350 R-10 Dad's: 2007 GMC Sierra Classic 2500HD SLT Mine: 1982 Chevy Silverado 6.2L Diesel K-10 |
02-10-2016, 06:04 PM | #34 |
Great looking set up and GREAT shifter head!! haha
02-11-2016, 02:48 AM | #35 |
Does anyone know of a shop in the Bay Area that has and can install cb/antennas?
02-16-2016, 05:17 PM | #36 |
They are not at all difficult to install and set swr, if a person is deliberate about it. If nobody suggests a place in your area, a lot of times interstate truck stop staff will know who might be good locally.
jjmorrse 86 C30 crewcab big dooley. 454- 400 |
02-17-2016, 01:05 AM | #37 |
Thanks!
02-19-2016, 10:18 AM | #38 | ||
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
