Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 03-14-2016, 06:09 AM   #26
64k10burb
64k10burb's Avatar
Re: New guy alert/Never Ending Project
Originally Posted by padresag View Post
those rubber insulated front rad mounts were only on suburbans and panels. more than likely to compensate for the more secure mounting of the longer body style of the suburban and panel over the shorter standard cab of the p/p. to give the front end a little more flex
ron
Thanks, I suspected as much. I have had ZERO luck finding them. Fabricating a standard mount is not a problem, I was just hoping to find the OEM type to allow the necessary flex. I will have to put some thought into my fabricated mounts......
Brian
1969 c-10 short/wide/6L LS swap
1964 k10 suburban project
1964 Falcon sedan delivery rescue project
64k10burb is offline   Reply With Quote
Old 03-14-2016, 10:42 AM   #27
padresag
steele rubber may be able to help you. they may be able to make up a set but it would be a one off deal.
ron
padresag is offline   Reply With Quote
Old 03-14-2016, 08:22 PM   #28
Dsuper5
Dsuper5's Avatar
Hey 64k10burb
I might be able to help you out, will post a pic of what i have this evening.
Eddy
Dsuper5 is offline   Reply With Quote
Old 03-16-2016, 12:47 PM   #29
64k10burb
64k10burb's Avatar
Well, that's not a worst case by far, but uglier than I had hoped. At least there still isn't much rust.
I knew I had some DIY-ish repairs going on in the quarters.....I estimate that I removed at LEAST 2 gallons of kitty hair and mud from the passenger side quarter panel. After a couple smacks with my fist, a large pucker that was full of mud popped out.
I will still need to replace the wheel well lip and the butchered lower rear section at a minimum. Access from the inside would sure make things easier, but I'm hoping not to have to go there.
Brian
Old 03-17-2016, 01:19 AM   #30
Dsuper5
Dsuper5's Avatar
Here you go, PM me with your zip
Old 03-20-2016, 02:34 PM   #31
64k10burb
64k10burb's Avatar
PM SENT
Here are the passenger side sliding window frames ready for reassembly.
I knew these fenders felt heavy....I guess the same "bodyman" worked them too. I guess the extra dirt also factored in
Brian
Old 03-22-2016, 08:02 PM   #32
64k10burb
64k10burb's Avatar
I picked up my glass last night and got a bit of work done today.
I do have a few more questions tho
My new glass was cut by coping replacement glass and I didn't have the latches for the sliding windows until yesterday. It looks like the latching mechanism will be binding on the edge of the glass..not good.
1. Should the sliding window have a hole or notch at the edge for latch clearance?
2. How does the latch attach? glass setting tape?
3. One of my 4 sliding windows has a glue on felt seal instead of in a crimp channel. What glue should I use, epoxy, contact cement,????
Sorry for the ignorance, I have read a lot of threads, but I don't recall anything on these items. Thanks in advance!
Brian
Old 03-25-2016, 08:41 PM   #33
64k10burb
64k10burb's Avatar
Woo Hoo I finally got an uninterrupted shop day...no appointments no emergency phone calls, I never even left the compound!
I got a good start on the radiator support repairs, knackered mounts removed from the frame, and started some battery box maintenance.
It ain't pretty but it's gonna work
Brian
Old 03-26-2016, 08:51 PM   #34
RANDY COX
RANDY COX's Avatar
I did the same thing to my radiator support on the passenger side just patched it up...good as new...can't be seen but now It's bolted securely down...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 04-01-2016, 08:55 PM   #35
64k10burb
64k10burb's Avatar
I agree Randy, work fine last long time!
Well, I needed to peel the "chin" off of my hood for rust repairs. It was worse than I thought, BUMMER.
I will order a replacement chin piece, but the inner support must be patched. I will wait for the patch panel before rebuilding the corners of the brace.
I need to be sure it all fits together.
Brian
Old 04-02-2016, 07:03 AM   #36
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Nice work.
The Sea Mist Jade will look great.
Old 06-07-2016, 10:00 PM   #37
64k10burb
64k10burb's Avatar
I finally got back to the burb, and my air compressor kicked the bucket.
I did get a few things going. Is the heavy connector plate on the bottom of the rocker/quarter junction normal?
How about the quarter being spot welded and stitch welded at the jam?
I swear the bozo's that painted this thing last must buy body filler in 5 gallon buckets!
Brian
Old 06-08-2016, 12:16 AM   #38
Captainfab
60-66 Nut
Yes the reinforcement plate across the rocker and quarter seam is original. I don't recall any stitch welds in the jamb though.
Old 06-08-2016, 07:34 AM   #39
64k10burb
64k10burb's Avatar
Thank you. I didn't think the rocker had ever been changed, but the plate just looked cobbled on. It has clearly been there a long time.
I will post better pics of the odd looking welds when the air compressor parts show up and I can clean the seam better. It almost looks double layered, but the spot welds look right and the rocker looked original as well.
Brian
Old 06-08-2016, 08:52 PM   #40
RANDY COX
RANDY COX's Avatar
WOW our making some headway, my hood was toast it was rotted at the rear corners and the inside panel was rusted really bad someone at one time had tried to patch it up and it looked horrible I got lucky a found a rust free hood for 200.00 bucks couldn't beat that price. It's always interesting to see what some previous owners have done to patch things up, my old 70 Burb 4x4 the lower panels were rusted through and they had just crammed newspaper in there and then bondo over it.. All that does is just create moisture when it gets wet and causes it to rust even more...anywho patch it up paint it up and go on..
1964 BBC 402 4x4
Old 06-08-2016, 11:26 PM   #41
64k10burb
64k10burb's Avatar
Thanks Randy. WOW $200 is a great find for a rust free hood. I didn't look too hard, the few I found still needed repairs and were priced more than I wanted to pay.
We did some mud er up and paint jobs for used car lots in my dad's shop when I was a kid....WOW that was almost 40 years ago, and before my dad became a resto only shop. Hey, we had to eat somehow
These days, I will drive a truck with rust holes before I will mud them up and make it worse!
Brian
Old 06-22-2016, 09:40 PM   #42
64k10burb
64k10burb's Avatar
Red face Re: New guy alert/Never Ending Project
Did you ever have one of those days....for a week?
Brian
Old 06-22-2016, 10:04 PM   #43
64k10burb
64k10burb's Avatar
At least my air compressor is working again!
The more I cut the more hidden holes I find.
Oh Well cut-grind-scribe-grind-repeat....soon I'll be able to get the welder out.
Does anyone have a picture of what the box inside the quarter panel/rocker junction should look like? If not I will just close it in before I start tacking the floor back in.
I already have to repair the rear floor brace, so I can add in whatever is needed.
THANKS!
Brian
