Old 12-01-2003, 07:34 PM   #26
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Probably these. www.xposedvisionz.com
www.killerridez.com
I guess I missed this post, but since I started you on this mission, I figured I could help you out. There was an issue of Street Truck that has a Z'ed chassis. If it wasn't them, it was one of the main mags. It has documented pictures of the process.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-01-2003, 08:23 PM   #27
SCOTI
SCOTI's Avatar
Streetrucks had an article covering this on a 65(?) Burb. Work was done by IFCustoms I believe.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-01-2003, 09:27 PM   #28
loweredd
www.loweredd.com
loweredd's Avatar
I should check that out. I have all those at home. I will leaf through some Capt. I think I remember the 65 Burb. It had 22's on it, right SCOTI?
Thanks for the info boys, this is what I have been looking for.
loweredd is offline   Reply With Quote
Old 12-01-2003, 09:33 PM   #29
Izzy
Trucker.
Izzy's Avatar
Correct, here are the pics from IF's site.
http://www.ifcustom.com/projects/pro...20suburban.htm
I personally feel some of thier work is quite shoddy but I'm sure you know what you're doing.
Izzy is offline   Reply With Quote
Old 12-01-2003, 09:59 PM   #30
loweredd
www.loweredd.com
loweredd's Avatar
I was just going to post this picture.
I've done 3 other trucks other than this one, and never needed to Z a frame. I was a certified pipe fitter in UT when I lived out there working at the local power plant. I can weld and do whatever I need to do, just wanted to see there approach. I wouldnt have thought to do it the way they did. I would weld a fish-plate over the frame on the outside and inside AFTER welding it like they did, but that's me.
Old 12-02-2003, 12:18 AM   #31
PJ_STYLES
Rockers1/2"off the ground
PJ_STYLES's Avatar
Question
I understand the concept of "z"'ing a frame but i was wondering and can't figure out do you have to lower the motor back down? shorter motor mounts so your drive train all lines up again?? or something? And i assume the steering colum would be all at a different angle so you need some joints? Could someone explain what has to be changed AFTER is it "z"'d thanks!
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca
PJ_STYLES is offline   Reply With Quote
Old 12-02-2003, 12:49 AM   #32
loweredd
www.loweredd.com
loweredd's Avatar
you also cut the front and move it like the back of the fram section you are moving.
Old 12-02-2003, 01:00 AM   #33
PJ_STYLES
PJ_STYLES's Avatar
Question
huh? sorry i don't understand. The front frame rails?
Old 12-02-2003, 01:03 AM   #34
loweredd
www.loweredd.com
loweredd's Avatar
check out the link the fiveeight posted. They have pictures of the front section z'd too.
Old 12-02-2003, 01:28 AM   #35
SCOTI
SCOTI's Avatar
PJ Styles, the front frame horns must be lowered the same amount as the 'Z' in the frame (or more if done in conjunction w/a bodydrop). The motor/trans position doesn't change in relation to the immediate framerails it's cradled in, but it does get raised in relation to the body. So you have to make sure you have adequate hood clearance, the trans tunnel has to be clearanced, as well u-joints for the steering column.
And yes @ the time the article was printed it sat on 22's. I'm hoping the article was just covering the basics & that they also went back w/some fish/boxing plates to tie it all together structurally(sp?).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-02-2003, 01:32 AM   #36
loweredd
www.loweredd.com
loweredd's Avatar
Yeah PJ, the link has ALOT of pictures. I need to U-joint the steering shaft anyway now. It's hitting the A-arm, just like that one does.
Old 12-02-2003, 12:18 PM   #37
Izzy
Trucker.
Izzy's Avatar
Sad thing is they didn’t. They never clean up their work, just take a look at some of their finished work on their site.
Old 12-03-2003, 04:49 PM   #38
98L150
///Relaxed Atmosphere
98L150's Avatar
72 z'd frame pics
Here are few pic's a friend of mine sent to me of his 72 that he is in the process of z-ing the frame.
98L150 is offline   Reply With Quote
Old 12-03-2003, 04:51 PM   #39
loweredd
www.loweredd.com
loweredd's Avatar
that's a crazy paint scheme. That's not stock is it?
Old 12-03-2003, 04:52 PM   #40
98L150
98L150's Avatar
Here anothter pic
pic 2
Old 12-03-2003, 04:53 PM   #41
98L150
98L150's Avatar
One more pic
pic 3
Old 12-03-2003, 04:54 PM   #42
98L150
98L150's Avatar
Last pic
last pic of inprocess I have
Old 12-03-2003, 04:54 PM   #43
loweredd
www.loweredd.com
loweredd's Avatar
Let me just say this. Thank You. That is exaclty what my first post was ALL about. Looks awesome. What size wheel/tire combo is he going with?
Old 12-03-2003, 05:10 PM   #44
98L150
98L150's Avatar
Tire size
Loweredd, I belive the tire size on 72 is 255/45 0r 50 - 17. I do know they are 17x8 up front and 17x9.5 onthe rear. There is a steering column issue her will have to adress by adding some knuckles to the column to avoid the upper control are. The paint onthe truck was something the previous owner dod onthe truck befor Steven bought it. I will find out what tire size he has and advise. Ther is also a hood hingle issue he will be dealing with; most likely go with a Sasche Road sytle hingle to open the hood to clear the tires.
Old 12-03-2003, 05:19 PM   #45
loweredd
www.loweredd.com
loweredd's Avatar
He's just z-ing to get Super low?
Old 12-03-2003, 06:12 PM   #46
98L150
98L150's Avatar
Z-ed Frame
Yes he just z-ed the fram to ge the truck as low as possible and keep the floor stockwith exception of the enlarged transmission tunnel he will have to do.
Old 12-03-2003, 09:38 PM   #47
72MARIO
72MARIO's Avatar
Does he ahve droped spindles ? I think he would.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-03-2003, 09:47 PM   #48
N2TRUX
Happy to be here
N2TRUX's Avatar
Jeff, Whose truck is that?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-03-2003, 10:27 PM   #49
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Pardon my french but.....
F*#K yea!! That's the plan for the next project.
FuelCellGuy is offline   Reply With Quote
Old 12-04-2003, 01:17 AM   #50
PJ_STYLES
PJ_STYLES's Avatar
Question
What is the average drop you can get by "Z" ing the frame?
