Old 11-26-2003, 10:36 PM   #1
loweredd
www.loweredd.com
loweredd's Avatar
Z-ing the frame
OK, who has done this? I want some pictures. 1.5 crossmemeber drop is not going to cut it for me at all.
loweredd is offline   Reply With Quote
Old 11-27-2003, 12:00 AM   #2
BigChevMan
My Thoughts Exactly!
BigChevMan's Avatar
what exactly are you trying to accomplish? z-ing will be a lot of work that you don't really need.
BigChevMan is offline   Reply With Quote
Old 11-27-2003, 12:38 PM   #3
loweredd
www.loweredd.com
loweredd's Avatar
I'm trying to get the rocker on the pavement. What else would you suggest. I need to be 3 inches lower. There will be a lot of work, BUT..................it is going to be needed.
Everyone is doing a 1.5 inch crossmember drop. Thier A-arms are touching the ground already when aired out. My arms are not even CLOSE to being on the ground when I'm at 0 psi.
Old 11-27-2003, 01:11 PM   #4
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Do you....
have 2 1/2" drop spindles??
FuelCellGuy is offline   Reply With Quote
Old 11-27-2003, 01:52 PM   #5
loweredd
www.loweredd.com
loweredd's Avatar
No.
I have 3"
Old 11-27-2003, 09:32 PM   #6
BigChevMan
BigChevMan's Avatar
I don't see how your 3" from the ground when your body style truck's frame is above the level of the body anyway. you may want to look into a fatman fabrications front crossmember which will allow you to lay body front to rear with the right size notch.
Old 11-28-2003, 01:54 AM   #7
BaggedC10
Under construction!
BaggedC10's Avatar
Wow, something isn't right here.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 11-28-2003, 11:04 AM   #8
FuelCellGuy
FUEL CELL GURU
Pics....
do you have any???
Old 11-28-2003, 05:02 PM   #9
loweredd
www.loweredd.com
loweredd's Avatar
I will try to get pics.
My frame is lower than the body. It is lower, trust me.
There is not something that is not right, it is simply the fact that I have a 32" tall tire.
I will try to get some pics tomorrow. I need to clean the truck off and get some pics for my website, since I have pics on there of every thing else.......
Old 11-28-2003, 05:04 PM   #10
loweredd
www.loweredd.com
loweredd's Avatar
The A-arms are bottoming out on the crossmember. That's why I cant go lower. I can also NOT lose any of my bag cup, cause then I cannot "untuck" the wheel to turn.
Old 11-30-2003, 06:48 AM   #11
TIMSPEED
TIMSPEED's Avatar
You MAY wanna consider running just a TAD shorter tire...more along the lines of STOCK size (275/40 20 would work)
IMHO, if you're running 305/50 20's up front WITH bags... you'll NEVER lay front bumper without BIG $$$ or simply body drop it.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 11-30-2003, 02:19 PM   #12
kdubaz
I've done a lot of body drop stuff, as well as crossmember sectioning, z'ing, etc... My 22's on my NBS Fullsize are 28" or so tall. I used drop spindles and hydraulics to lay it on the ground. Get some smaller tires man, that's going to help a LOT. If you had 245/35's on there, you'd have an extra 6 inches or so.
Kevin Whipps
Writer & Photographer
Whipps Industries.com
kdubaz is offline   Reply With Quote
Old 11-30-2003, 03:30 PM   #13
loweredd
www.loweredd.com
loweredd's Avatar
Oh man, no way is there going to be a 245/35. I dont care if I got them free.
I think that I will get about an inch shorter sidewall when I get new tires though. These are the same as the SS Silverado. They are 275/55/20. The SSR has a 295/40 I think it said on the sidewall, but they didnt look that good. Looked like the rim was too wide for the tire.
Old 11-30-2003, 05:44 PM   #14
FuelCellGuy
FUEL CELL GURU
Duh!!!!
I didn't see what diameter tires you were running. My tire diameter is 27" on the front. I am running a 17" x 8" wheel with 255/50/ZR17 BFG's. My crossmember lays with this however, to lay rock, I would need a crossmember sectioning or body drop. Hope this helps. Later, FCG
Old 11-30-2003, 07:02 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
I think you need to cut holes in your hood. That should let you lay rocker, and run your 4wd sized tires
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-01-2003, 12:34 AM   #16
loweredd
www.loweredd.com
loweredd's Avatar
I dont need to cut holes, it is about 2 inches under the bedrail, so I should be fine. Why are ya bustin my chops?
OK, let's say this. I have a set of 24 inch wheels to put on my truck, but it wont lay out. I need help. Does anyone have pics of thier Z'd frame?
Thanks.
Old 12-01-2003, 02:10 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
I'm not trying to rag on ya, just trying to make sense out of what you want.
If you want to run a tall tire in the front, it's going to be hard to get it low. That's what everyone is trying to tell you. You need a shorter tire up front, regardless of the size of rim you plan to run...
Old 12-01-2003, 02:13 AM   #18
kdubaz
Yeah thats what I'm saying. You could lay your truck out on the super swampers you're running if you want, but it ain't gonna be easy. Get a 275/45 or something. They're cheap as hell and easy to find.
Kevin Whipps
Old 12-01-2003, 12:33 PM   #19
loweredd
www.loweredd.com
loweredd's Avatar
A 275/45 is kinda what I was thinking of going with when I got new tires......this is beside the point. I was looking for pictures. This is all I wanted in this post. Not "your tires are too big". I know they are large, and this is why Im doing the work.
Old 12-01-2003, 01:50 PM   #20
Buddy Lee
Buddy Lee's Avatar
We just z-ed a 94 model F/S, although I am not sure if there are pics on the site yet. You could go by the shop and check the truck out. I think we did it 3/4" to get it to lay rockers with 22's on a stock floor body drop.
Buddy Lee
www.xposedvisionz.com
www.killerridez.com
"when you just gotta have a KILLER ride!"
Buddy Lee is offline   Reply With Quote
Old 12-01-2003, 04:57 PM   #21
loweredd
www.loweredd.com
loweredd's Avatar
What website? And by the way, thanks for a "real" answer.
Old 12-01-2003, 05:05 PM   #22
Buddy Lee
Buddy Lee's Avatar
Check the Killer Ridez web site...the addy is on my Sig. The truck is either under the updated links on the home page at the bottom or you can find it under the customer page.......Its a 94 chevy black and silver.......
Buddy Lee
www.killerridez.com
Old 12-01-2003, 05:48 PM   #23
loweredd
www.loweredd.com
loweredd's Avatar
They've got it on there, but no close ups of the frame shot. I can get it done, I just was hoping that I could see a finished product.
Old 12-01-2003, 06:53 PM   #24
grnddwn
belly dragger
grnddwn's Avatar
[QUOTE]Originally posted by loweredd
[B]Oh man, no way is there going to be a 245/35. I dont care if I got them free.
Whats wrong with a shorter tire?
grnddwn is offline   Reply With Quote
Old 12-01-2003, 07:20 PM   #25
loweredd
www.loweredd.com
loweredd's Avatar
I dont think it looks that good.
