Old 02-02-2023, 09:08 AM   #26
K10-Kansas
K10-Kansas's Avatar
Re: Classic performance parts steering wheel crooked
Originally Posted by Montierth View Post
Ahh I see. Now I gotta look at mine. Assuming the support/brace would have the nipple regardless if automatic or clutch truck.
Maybe a longshot but I think I saw in a previous post your dash was bent. Would that play into this at all? Just a thot?
Nah, the only 2 factors that relate to the degree of offset of the gear selection indicator from noon is the relationship between the 2 screw holes in the column for the selection indicator and the notch in the column for the brake assembly nipple.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 02-09-2023, 05:37 PM   #27
K10-Kansas
K10-Kansas's Avatar
Originally Posted by Johnl48 View Post
Tilt column I got here from Don D lined up perfectly. No issues
Hi. Was it a CPP column? Do you still have the nipple on the brake assembly housing?
Old 02-10-2023, 10:20 PM   #28
K10-Kansas
K10-Kansas's Avatar
After 3 weeks of CPP not doing anything to get me an answer on what to do about their offset columns, I gave up and took the column back and bought an IDidIt column. Problem fixed.
Old 02-15-2023, 10:54 AM   #29
Jason Banks
Jason Banks's Avatar
I was looking at a truck on Bring A Trailer and it has a tilt column.
Was watching the video and it has the indicator crooked - https://youtu.be/2o0nSqZsBME?t=199
Then I went and looked at the pictures and picture 99 shows it's crooked too.
Jason Banks is offline   Reply With Quote
Old 02-15-2023, 10:59 AM   #30
Jason Banks
Guess I should link to the auction - https://bringatrailer.com/listing/19...10-pickup-119/
Seller chimed in and said he thinks it's the CPP column.
Old 02-15-2023, 08:29 PM   #31
K10-Kansas
K10-Kansas's Avatar
Wow looks exactly like mine did. I can't believe anyone would settle for that. A builder I talked with said he grinds the brake assembly nipple off so that the CPP columns will sit straight but that is a terrible idea. That nipple is part of what keeps the column from pushing into the driver during a head on collision.
Old 02-16-2023, 09:12 PM   #32
Casper42
Casper42's Avatar
or, perhaps another Frankenstein'd truck. Common sense tells me if it were a problem with the manufacture, it would be more commonly seen, and/or corrected. (no brainer)
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 02-19-2023, 09:59 PM   #33
Casper42
Casper42's Avatar
I may have found your issue on fit. While looking thru the Factory Assembly Instruction Manual, I came upon the steering column install. It seems the "Selector Plate Gate and Lever" at the bottom of your column is, well, adjustable within the steering jacket. that leads me to believe if one does nothing with it, your column may not line up as in your example.
Old 02-20-2023, 02:28 AM   #34
Richard
Think that the adjustable gate has to do with where the indicator lines up on the lens. The lense and housing are attached to the column. Only way to make it center is to rotate the column. Which would require clearancing the hole or grinding off the nub.
Richard
Old 02-23-2023, 11:54 PM   #35
K10-Kansas
K10-Kansas's Avatar
Exactly, I talked to the CPP techs and they said there is no way to make it straight.
Old 05-03-2023, 01:15 AM   #36
Dodge68charger
Ran Into The Same Problem Today With The Shift Indicator Being Off But Mines a Tilt Column Out Of a 70s Van
Dont Wanna Grind The Nipple Off But No Other Choice
Dodge68charger is offline   Reply With Quote
Old 05-03-2023, 06:21 AM   #37
K10-Kansas
K10-Kansas's Avatar
And the gear selector can't be relocated right? Because it fits into a slot right?
Old 05-03-2023, 10:11 AM   #38
Dodge68charger
The Steering Column Cannot Be Rotated As It Is Locked Into The Tab On The Brake/Clutch Bracket.
I Will Grind Off The Tab This Weekend.
A Ididit Column Is Not In The Budget Right Now
Old 05-03-2023, 10:33 AM   #39
K10-Kansas
K10-Kansas's Avatar
Personally I would cut the notch in the column and not grind off the nipple for the brake pedal housing. To some degree that notch in the housing serves that a biit of a safety to reduce the force that the column would push into the cab during a wreck.
Old 05-03-2023, 11:38 AM   #40
Dodge68charger
Ya I Was Kinda Thinking The Same Thing
Old 06-16-2023, 08:38 AM   #41
K10-Kansas
K10-Kansas's Avatar
I just wanted to follow up on this thread and say, I switched to using an iDidIt column and have been very happy with it.
Old 06-16-2023, 06:25 PM   #42
Casper42
Casper42's Avatar
I installed my CPP column - easy peezy no problem and very happy. it's clearly high quality, which confirms my suspicion that way-early productions of this have been ironed out, or people had Frankenstein rigs they were trying to shoe-horn them into. Also, the entire column can be rotated, for fine tuning where you want it, thus I have no clue what the issue was with yours....that's just bizarro.
