Re: Comp Cams
Never mind
Re: Comp Cams
Never mind
#3 | |
![]() Join Date: Apr 2016
Re: Comp Cams
Re: Comp Cams
Re: Comp Cams
Thanks for the option.
"gotta love something that works without a computer" |
Re: Comp Cams
![]() Join Date: Jun 2022
Re: Comp Cams
The Jeep forum I'm on has a lot of folks who had been happy users of Comp cams for years, but have had problems wiping them on break-in in recent years
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
Re: Comp Cams
Before you install the next cam, you probably want to watch this video. They actually take a flat tappet lifter on a grinder after the blue it up and you can see the problems. He shows they were Crower lifters.
At this point, I would spend the dollars and put a roller in it. https://www.youtube.com/watch?v=MbRjAMhCEJk |
#9 | |||
Re: Comp Cams
Re: Comp Cams
I'm in the roller camp. I didn't want to have issues so I went retro fit with all COMP. This was back in 2018/19. The lifters I purchased with the roller setup were absolute trash. I ran them until early 2020 before swapping them out with Howards. No problems since and I run it around quite a bit. COMP 11-422-8 COMP 854-16 (replaced)$$ Howards 61161 Hth, -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#11 | |
Re: Comp Cams
#12 | |
![]() Join Date: Jul 2000
Re: Comp Cams
You can buy this kit or the parts individually. It's a good way to go, but not inexpensive. Complete kit minus cam retainer plate: https://www.gmperformancemotor.com/parts/12371056.html On another note, you will not beat a GM cam for reliability. There are several available, from stock L31 Vortec truck engine to cams used in SP350 and SP383 crate engines. https://www.gmperformancemotor.com/category/SB169.html
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#13 |
Re: Comp Cams
wrong thread...
#14 |
Re: Comp Cams
Started with i believe with a precision power flat tappet cam, stock cam, lost oil pressure after 100 miles, tore down, went with a Howards cam Slight upgrade from stock, well that one didnt make it through break in, collapsed lifter, Howards cam,s come with warranty, called them right away with motor still cooling down, They're were Great , Customer service was very good, they warrantied the cam and set me up with a roller cam and lifters, never looked back, almost 4000 miles on build and still Great, i also have a Very Good Machine Shop where im at, the Shop covered the Difference in Price and sent the cam back both times, so i wouldnt have to wait on the refund, I agree with Most Here, if you go Flat Tappet, look for something old stock, Ebay, Facebook, but i wouldnt hesitate to go with another roller cam in any build
Good Luck with your Build
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
#15 | ||
Re: Comp Cams
#16 |
Re: Comp Cams
Jones Cam Designs uses only the best of the best cores, and sells American made lifters. I can't think of anyone else I would trust. A flat tappet cam I bought from Mike Jones many years ago was a work of art compared to the mass market one-size-fits-all guys. Everything from lobe lift to event timing measured spot-on, not +/- a few thousands or a few degrees like a Comp cam I had in the shop. http://jonescams.com/
And these days even roller cams may not be the answer. Did you guys see the Roadkill Garage episode where a brand new Comp roller lifter essentially fell apart after the engine had been run for only a few minutes? Comp apologized, said it was a known problem(!), and sent them a higher quality set. Nice to know they sell some roller lifters that work and some that fall apart, huh?
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 02-11-2025 at 06:50 PM. |
#17 |
Re: Comp Cams
I live next door to Alaska in the Yukon, it's a real challenge to get quality machined parts here. On top of it we pay twice the price, not America's fault, our greedy government. So it's a one shot deal after replacing crank, bearings and a full rebuild.
#18 |
Re: Comp Cams
That's exactly what I'm looking to avoid. No second chance with an inferior cam set-up as it's the most crucial element of break in. I'll look into the "Jones" company.
#19 |
Re: Comp Cams
#20 |
Re: Comp Cams
#21 |
Re: Comp Cams
#22 | |
Re: Comp Cams
Had a buddy order a custom grind from Straub. Before he even installed the cam, he decided he wanted one with less duration. Straub ground him a new one and let him return the old one for a full refund.
#23 |
Re: Comp Cams
Great service.
#24 |
Re: Comp Cams
Originally Posted by Getter-Done View Post I have always had good luck with Crane Cams. Quote: Originally Posted by realsteelGM View Post I remember crane cam decals as a young boy while making model cars. They have certainly been around. I am going to look into them, see if they have old stock cams tucked away. I guess over the years the myth becomes bigger than the actual product. I remember building a few engines and degreeing the cams. They were literally all over the place. You had to take a pot guess half the time as 1 exhaust lobe would be way off from the next exhaust lobe, hence the reason they closed. They sounded great, but the actual performance was debatable. I have rebuilt a few LS/LT Gen 5 engines using cams by a few modern cam companies. They are dead nuts on. The new CNC cam grinders do exactly what you program them to do. |
#25 |
Re: Comp Cams
The base cam in 327 and 350 engines for many years was the GM#13896929, often known as the "929" cam. I suspect it would work just fine with a 283. In fact I think it was used in 283s in the 1960s. Specs are 195/202, .390"/.410".
There are a few NOS 929 cams for sale on the Internet. They should never create a problem due to poor machining. However, I'm not sure where you can get the best lifters.
| Bookmarks |
