VA72C10
![]() Join Date: Mar 2008
Re: 1967 C10 Custom Big Window
From no tuck
to tuck ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Sofa King Crazy!!
Yeah! You can see I gained.....uh lost at least two inches! Made a big difference with the notches.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() Last edited by Slick67; 03-17-2010 at 10:13 PM. |
Under Construction
nice work David!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
67cheby
![]() Join Date: Sep 2008
looking awesome man
David, your truck makes me jealous, yours is painted and looking good, mine runs but is nowhere near done, if ever! Keep it up, you are doing a great job, btw, I will get you do do a sketch of the camaro, pm you later.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
Man! That's looking great! I'm really diggin' the air cleaner.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser 71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished 93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's 98 Chevy short bed DD 97 Z71 3 Door 51 Suburban-S-10 swap "What other hot rod can you carry 7 of your friends in" ![]() |
Sofa King Crazy!!
Oh yeah, can't say I have ever seen another so I'm diggin it too!! Thanks bro!!
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
![]() Join Date: Nov 2008
Man bro, that truck is looking sweeet! I knew the engine scoop mod would look bad ass!...Good job!...
#9 | |
Sofa King Crazy!!
Can't wait to gitter done!
Thanks for the compliments! When I have people like you and James and Heath saying that, it must be coming out alright for my first build. That scoop was a true brainfart, but I must say it was a cool idea and I thought it would be original. Gotta figure out a good way to attach it to make it look like it's "floating" on top of the motor.
David, what are you using for an air cleaner. that will really make or break the bank for mounting it.
Sofa King Crazy!!
I am using a 6.5 inch round Mr. Gasket that I will probably have to cut down about 1 inch (maybe). The scoop is about 2.5 inches from the top to bottom and the cleaner is about 4 inches tall. The scoop is about 14 inches wide. I am thinking of using a little longer stud for my carb and making 2 braces one for the front and back that will hold the scoop just about .25 of an inch above the air cleaner. Bolting it to the carb studs should be sturdy and installing and removing should not be too hard.
Still Learning
Looking good! You'll be on the road in no time.
#13 |
Now what??
Looking real good! I love that color in the sun!
69 Long Fleet - Project 06 Ram 1ton Cummins 4x4-DD 01 Tahoe- wifes "The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi "A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell my, um, build ![]() ![]() ![]() |
#14 |
David, have you thought about using one of those flat K&N styles out of a new car, like 10" by 16" by 1", building a base and cover for it then mounting the scoop on it. This would give you more air into the engine. just a thought, I have always had bad luck with those little air cleaners. what do you think?
#15 | |
Sofa King Crazy!!
Thanks! I wish it was soon, but still looks like about 3 months or so if no bad luck.
I appreciate it! The camera just doesn't pick up the true colors on this truck, may have to let someone who knows what they are doing take some pics. Quote:
#16 |
awesome build david!
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
#17 |
Sofa King Crazy!!
Thanks Bro!
More pics coming after the weekend.......
#18 |
VA72C10
You know we'll hold you to that!
#19 |
Sofa King Crazy!!
Not the update that I wanted to give, expected to hear the motor crank for the first time. I did get a couple of other things done though. My intake is now installed along with some of the wiring under the dash. Got a new swivel water neck installed and painted a few parts like the transmission cover and the flex plate cover with krinkle black paint. Also installed a new trans filter. I also got the starter installed with a slight trim job on the flywheel cover. Didn't get enough done this weekend.....I'll try harder next weekend!
#20 |
VA72C10
Hey man, progress is progress! Looking good and almost there to get it fired up!
#21 |
Under Construction
looking good David.
#22 |
Remember Rome wasnt built in a day, Thats gunna be a very nice truck!
#23 |
low n' slo
![]() Join Date: Mar 2009
man its looking good david! i really need to swing by and gawk at it for a while..
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#24 | ||
Sofa King Crazy!!
Thanks Heath!!! Quote:
Anytime bro! You know you are welcome to come by whenever ya want!
#25 |
Sofa King Crazy!!
Here is a quick update from today. Got my brake pedal in, got my shifter linkage in, put my side mouldings on my bed and wheel arches, and got my cab bolted down for the last time. Only got pics of the mouldings for ya now. Nuke, you were right, these things really make it stand out!!!!
Tags |
1967, custom, lwb |
