#51 |
Re: How Many Miles Per Tank?
Work gets in the way of spending the time it would take to learn how to do a custom tune myself..So I am using a piggyback chip that has the 89 prom in it. It was suposed to correct early tcc lockup problem that the earlier computers had, but mine still seems to go into lockup at about 38mph..Anyway, I did drive it without lockup for a while and I like it better with it.1800-1900 rpm @ 65mph is pretty cool.
Thanks for answering my questions, you guys know your stuff.. |
#52 |
About 200 miles for mine to i got 35's and a Eldelbrock 600cfm haha.
#53 |
my 91 same setup bur with a 700r4 and tall gear gets 22-24 as well
#54 | |
EDIT: Just looked it up and it seems all of the ribbon cable 24 pin extensions are outdated. Most that want that capability these days are using live time emulators (that were just coming out at the time I used the cable extension idea).
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube Last edited by bnoon; 11-27-2012 at 06:01 PM. |
#55 | |
Just little tricks like this combined with other things is what allows me to get over 17 mpg around town in stop and go traffic. |
#56 | |
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
#57 | |
#58 | |
Probably best to use a calculator and decide what fits you best. Your 4th gear overdrive in the 700 is .70. That along with your prefered tire height, and the lockup converter, makes a 3.73 very streetable in my opinion. You can go to Vexer.com and use their speed calculator, play with tire height and gearings and watch how it affects speed and rpm, it's an interactive screen that's pretty cool. Hang on and I'll see if I can link it.... |
#59 |
http://vexer.com/automotive-tools/speed-rpm-calculator
Here you go. I plugged in your .70 overdrive with a 28" tire, converter locked up at 100% efficiency, and 3.73 gears and it says 2200 rpms for a 70 mph cruise speed. Of course it would be lower if you run say,,,a 30" tire...it drops to 2,000 rpms at the same speed. Plug in some different stuff and move the slider around and see what you think. |
#60 | |
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
#61 | |
#62 |
before the debacle that I have now come across.. my 85 gmc carbed 5.7L got 12.4 mpg..thats daily driving... freeway.. city... everything...
#63 |
In my 83 I get 6.24 MPG around town and about 12.3 MPG on the highway. This is a mild 355, a TH400, 4.10's, and 38x15.50 MT Baja Claws.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
#64 |
I just got my C20 a couple of weeks ago, and so far have gone from 10 mpg to 15+ mpg highway at 65 mph. Plus after the last of my initial round of mods I hope to sit at 17-18 mpg highway. City I think I am doing 12+ or so. I concern myself with highway mostly as that's where I drive 80% of the time, and 4.11 gears will keep the engine working to hard getting the truck moving.
The previous owner had dual exhaust installed, and it has 9.5x16.5 tires, and the 14 bolt came with 4.11 gears. I curved and added a HEI distributer, and tuned the Q-jet to the most I can with out a rebuild. I plan to add headers, new exhaust because the old one is shot, and dual electric fans to get the last of the drag off the motor. My next big mod is to drop in a T200R4 which will sit my rpm at 2200 rpm at 70 mph. I am choosing this trans because its practically a direct replacement for T350 with only new holes needing to be drilled. No drive shaft mods like a T700R4, and its just as strong with a close ratio. My current 9.5x16.5 tires are some sort of HT tread so I will get 255/60 or 70/17's with highway tread on probably H2 rims. After all the mods I am hoping for 20mpg highway. |
#65 |
![]() Join Date: Jul 2012
87 K20 with a 6.2 diesel, TH400, 4.11 gears, stock height tires (31" or so), pulling gooseneck horse trailer (combined truck/trailer weight of about 12,500#). I'm getting 11-13 mpg. I just got the truck a little while ago and couldn't believe these figures when I calculated it out. It's about the same as my 72 C20 gets empty...with a fresh tune... Maybe it's the 80 psi in the tires...
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
#66 |
i get about 140 to a tank, my engine is tired and my cam is too big!
"DON'T TOUCH THE TRIM!!"-Early Kyler |
#67 |
86 short bed, 305/700r4: I get an average of 300 miles to a tank, as little as 190 and as many as 360 depending upon my driving style for that week. so I average about 20 MPG.
![]() btw, this is considerably better fuel economy than my old truck, a 97 ford ranger with 4.0 and A/T. it was averaging about 9MPG I have everything to do a tune-up but have not had the time. Hoping i can get to that tune-up this coming weekend. I hope it is a 3 day weekend so i have enough time to get done all the things i want to get done. -Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
#68 | |
#69 | |
I do agree that there is a lot more to MPG than the engine so I was glad to hear you say that. And I have a 350 in my truck. Without changing the front and rear gears to a 2.89 or something, there's no way I will achieve the economy you are claiming in your truck with the 502 (I have 4.11 gears and an SM465 tranny). Maybe one thing you are missing in your list is load % on the engine while cruising. I'm really not trying to start anything, but if you could clarify how in the heck you did achieve these numbers, please enlighten us! Share the wealth man! ![]()
1975 GMC Sierra Grande K25HD 350-4BBL 4sp LWB 2009 Infiniti G37S Sedan w/Stillen sway bar kit & K&N Typhoon dual snorkel intakes ASE certified for brakes, electrical diagnostics and heating and A/C & EPA certified in R12 and R134a |
