Old 04-04-2017, 03:43 PM   #51
Devil Pup
Devil Pup's Avatar
Re: Complete build change. Lifted 2wd
Originally Posted by kehstr View Post
Yes, I did it. It depends if you bought the plate to mount the speedometer, or if you build one. I built mine, and of actual work working just on the speedometer, I think I have about 12-15 hours, trying to make everything perfect (I'm a perfectionist). If you bought the bracket, it would cut down on probably about 3 hours not having to do a little bit of trial and error to make everything fit correctly, not to mention I think the plate would make for a better finished product.
Wow that sounds like a ton of work. I did buy the plate and box from Captianfab on here so hopefully that cuts down on the install time.
Devil Pup is offline   Reply With Quote
Old 04-04-2017, 04:03 PM   #52
kehstr
kehstr's Avatar
It definitely is! And I know for a fact that buying that plate will save on install time, at least 3 hours of my install time was making that plate, and doing little modifications so it would fit like I wanted it to.
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 04-04-2017, 04:05 PM   #53
Devil Pup
Devil Pup's Avatar
Good to hear, thats exactly why i bought it. figured by the time i make it im loosing money and time lol. any tips would be appreciated. Did you use the HP 4060 lights that were mentioned in that thread?
Old 04-04-2017, 04:44 PM   #54
kehstr
kehstr's Avatar
yes I did, and they go in with minimal modifications, just cut 2 of the 4 tabs off, and trim the other 2 and they go right on. One tip that will save you a lot of time, would be on the trip reset, instead of taking a screw to lengthen the trip reset button, just build up the "ramp" that moves the metal rods that reset the trip with some epoxy, so it moves those rods sooner.
@Chad's Fab
Old 04-04-2017, 04:49 PM   #55
Devil Pup
Devil Pup's Avatar
Nice, thats what i was hoping to hear. Gonna pick up a few of those sockets so im ahead of the game. how many did you end up needing? Thanks for the tip on the trip reset. looking forward to having one of those in this truck
Old 04-04-2017, 10:09 PM   #56
kehstr
kehstr's Avatar
I used 8. I agree it will be nice having a trip!
@Chad's Fab
Old 04-10-2017, 12:05 PM   #57
Devil Pup
Devil Pup's Avatar
Wrapped up all the brake lines we could this weekend. Made a tubing straightener from some wheels from Lowe's. worked decent.
We Decided to run the proportioning valve on the frame rail rather than off the master cylinder. My brother had these nice little stainless clamps that make the lines look really nice and uniform.
Old 04-10-2017, 12:13 PM   #58
Devil Pup
Devil Pup's Avatar
Pulled the front clip as a complete piece
Old 04-10-2017, 12:15 PM   #59
Devil Pup
Devil Pup's Avatar
Set the front clip on the new frame to see how it was gonna look.
Pretty happy with the height at this point.
Old 04-10-2017, 05:19 PM   #60
c10-72 II
Active Member
c10-72 II's Avatar
I can't wait to see this done! Bad ass
1972 GMC C2500 Tow Rig project
1972 C10 Air Bag project
1967 C10 Drag Truck project
1967 GMC Patina Special project
1968 C10 I have no clue what to do with project
1969 GMC C6500 I wish I had more money project
1986 K10 I have too many damn projects
c10-72 II is offline   Reply With Quote
Old 04-10-2017, 05:59 PM   #61
I Have No Idea
Awesome project!!!
I Have No Idea is offline   Reply With Quote
Old 04-10-2017, 06:21 PM   #62
Devil Pup
Devil Pup's Avatar
Originally Posted by I Have No Idea View Post
Awesome project!!!
Thanks guys!
Old 04-12-2017, 01:56 PM   #63
c10-72 II
Active Member
c10-72 II's Avatar
What's the height from the bottom of the fender to the ground?
Old 04-12-2017, 06:12 PM   #64
Devil Pup
Devil Pup's Avatar
I didn't measure it when i had it sitting on the frame. I will get a measurement next time we set it on.
Old 04-13-2017, 04:22 AM   #65
GR8-68
GR8-68's Avatar
Looking good, excellent job on the brake lines.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 04-13-2017, 01:48 PM   #66
Devil Pup
Devil Pup's Avatar
Thank you Im happy with how they turned out!
Old 05-08-2017, 02:47 PM   #67
Devil Pup
Devil Pup's Avatar
Well this weekend started out with a disappointment. We had our hopes set on getting the motor ready to go in. I ordered an AC-Delco transmission filter/gasket and had a corvette shift solenoid for the 4l60E thats goin. Everything was good until we pulled the pan. There was a Ton of what looked like clutch material in the pan. I knew this was a possibility considering I got the motor from the junkyard but i was optimistic. So now we either have to try our hand at rebuilding it or have it done. We've never done one before so any tips are appreciated.
This is after we wiped most the junk out. the whole pan was covered
holding up the whole project now
Old 05-08-2017, 03:00 PM   #68
Devil Pup
Devil Pup's Avatar
Since the tranmission is now gonna need some attention we finished up the brake lines. For anyone doing this style lift you'll quickly find that routing the rubber hoses for the caliper is a bit tricky. We went to the front of the control arm which required the hose shape to be slightly modified.
The hose still has slack at full droop and is out of the way of any steering components
The hoses ran through an existing hole in the frame and meets up nicely with the brake lines we made a while ago. using a horse shoe clip to retain them.
The rear end brake line also completed and has plenty of slack. We figured out a way to use the stock 2001 silverado brake cables in the factory brackets for the 69 so that should be an easy hook up also.
The frame is basically done. if only the transmission wasn't an issue, it'd be time to really start the swap!
Old 05-10-2017, 12:43 AM   #69
kehstr
kehstr's Avatar
when you wrap up the park brake cable setup, make sure you post pics. I hope to be able to do something similar with the rear end of my truck one day.
@Chad's Fab
Old 05-11-2017, 01:40 PM   #70
Devil Pup
Devil Pup's Avatar
Will do. I was surprised it looks like it should lay out pretty nicely.
Old 05-11-2017, 08:16 PM   #71
RichardJ
On your first page you had a picture of this reinforcement bracket you found on the later front end. I found the same reinforcement on the '76 C30 SRW that I took the disc brake parts from for my '67. I believe they added the reinforcement, because the brackets on the outside of the frame that the upper A-arm bolts to is a lighter weight pressed steel piece, rather than the former Forged Steel bracket, riveted to the cross member.
I used my '67 cross member with the Forged brackets and added the inside reinforcement brackets as well. I used the six cylinder coil springs, but everything else including the brake lines and forward mounted Combination Valve is from the '76.
I realize that you are well past the cross member, but the original, later Combination Valve mounting on the small cross member, under the radiator might be worth considering. It is hardly noticeable down there and there is already one usable mounting hole. Later you will need easy access to it, to hold the Metering pin in for bleeding.
Just a thought.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 05-11-2017, 08:58 PM   #72
Devil Pup
Devil Pup's Avatar
Just a thought.
Hmm ya I had wondered why it had that bracket. So that must mean these springs are 1 ton as well would you say?
as far as mounting the prop valve down there, we had considered it but ended up mounting it just behind where the motor would sit because I want the lines to go right up as close to the firewall as possible. hopefully keep it clean. Im hoping, like the front mount that it too is easy to get to. I appreciate the suggestion though.
Old 05-11-2017, 09:10 PM   #73
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on your new frame. Sorry to see about the trans. Could you find a decent used 4L60E to keep you going for now?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-11-2017, 09:15 PM   #74
Devil Pup
Devil Pup's Avatar
Thank you sir! For now as suggested by a few members im going to try and run it. worst case, im out fluid. . best case it works. lol. but yes if it comes down to it not working, I will look for a solid used one I think.
Old 05-15-2017, 12:16 PM   #75
Devil Pup
Devil Pup's Avatar
Well this weekend was a ton of work. Started by getting the cab off the bagged frame. was a bit sketchy because we had to do it in the dirt but it was surprisingly sturdy.
2wd lift, 67-72 chevy, lifted, lifted 2wd, ls swap
