#76 |
![]() ![]() Join Date: Jan 2005
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
More photos
#77 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Getting better looking by the day
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#78 |
#79 |
Did a few odds and ends this evening. I was looking at some photos of other trucks and realized I installed the shackle plates backwards, so I flipped them around.
Removed the box tubing spacers that were above the bump stops. Removed some extra metal that was welded to the front shackle bump stop and repaired a big crack in it. |
#80 |
More photos of the shackle bump stop
#81 |
Spent today working on the truck. I removed some 1" blocks from the rear axle. The axle perches are badly bent, so they will have to be replaced. I've got a set of new Perches, but I'm going to wait until the engine, transmission and transfer case are installed so I can get the pinion angle correct.
#82 |
I also removed the 3" body lift and installed new cab mounts and radiator support mounts. When I went to remove the custom long steering intermediate shaft, I discovered that it had been welded to the steering gearbox, and the gearbox shaft had its splines ground off. I was hoping I could use this gearbox, but I guess that's not happening.
The truck is finally at the final ride height other than the sag that will result from installing the engine, transmission, etc. |
#83 |
![]() ![]() Join Date: Jul 2003
Wow, that steering box is one of the worst I have seen. That's not a place for cobble jobs.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#84 |
I agree! The person who owned this truck was a menace with a stick welder. It appears that two different people did the welds I've found. Some of them are fairly decent, and the others are the worst I've ever seen.
#85 |
![]() Join Date: Oct 2012
Holy cow!
Scott 1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#86 |
Awesome find, and it's shaping up very nicely. This K10 short step is my dream truck. My 68 C10 short step frame off will be done in the spring, and I may convert it to 4x4 or sell it and get one like yours here. If you get further along with it and decide to sell or maybe trade, let me know.
Keep the posts coming! |
#87 | |
#88 |
Awesome! Glad you found what you wanted.
#89 |
Went to a wrecking yard this evening and pulled the license plate mount off of a 1993 GMC van. This will go on a sport rear bumper I bought recently.
#90 |
Finished up some small tasks on the cab mount replacement. The rear bolts that came with the kit I bought were an inch too long (9"). I couldn't find any 8" bolts locally, so I cut more threads on them with a die, and shortened them. I also welded square nuts to the cab floor under the tank since the originals had been removed for some reason.
One of the tank mount nuts was missing, so I welded a square nut in that spot. |
#91 |
I also removed the grille and started the process of removing the radiator support.
#92 |
Removed the mutilated radiator support and got the replacement bolted loosely into place. Had to add a thick washer to each of the front cab mounts to get the fender/door gap decent.
#93 |
Spent some time working out dents in the front fenders and hood. Also removed everything from the firewall. I will be welding in a patch panel to fix a mutilated clutch rod hole.
#94 |
It is good to see this rig in the proper hands to fix all of the tomfoolery.
#95 |
#96 |
All about them K’s
![]() Join Date: Jun 2014
Man I’ve been working a lot of hours at work this month and haven’t kept up with this thread as much. You’ve kicked total ass! I can’t believe that steering box. Stupid people shouldn’t be allowed to own welders. I can’t see how it didn’t leak like crazy heating the Input shaft seal up like that. Really really nice work cutting the bs on this truck!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#97 | |
#98 |
Repaired the mangled clutch rod hole in the firewall today. Had to cut the patch panel pretty small to avoid a brace that's right next to the hole. Also welded up several random holes in the firewall and in the fender over by the battery.
#99 |
A few more photos
#100 |
![]() Join Date: Jul 2021
You are doing a heck of a job on this ride. It is going to look great when you get through with it. Looking forward to seeing it when done.
Darrell ![]() 1972 Cheyenne Super C20 (Heavenly Too) (My Street Truck) 2000 S10 Xtreme (Black Magic) (My Drag Truck) |
| Bookmarks |
