Old 08-03-2011, 04:47 PM   #1
robnolimit
robnolimit's Avatar
63-72 Chevy P/U Rear Shock Mount System
Here it is. The first of our updated C-10 parts to come out of the project J.T. test truck. As we all know shocks are a key component for performance. But equally important is the location of the shocks. Remember, these were built as trucks, not performance drivers. So just as you update the motor and trans components it's important to upgrade suspension parts. Our new rear shock mounting system provides for the mounting of long stroke shocks. Even on lowered trucks, allowing the full travel of the rear suspension. Also we have recolated the shock position to mount them behind the axle, and outboard on the frame. This outboard mounting gives a wider stance for the shocks, making the truck more predictable and stable. As an added benefit there is now more room to run the exhaust over the rear axle. Installation is easy and only requires drilling four 3/8" holes. All of the mounts locate onto factory holes so no measuring is required. Start building true performance today. Parts are in stock and ready to ship. If you are adding shocks, we will need to know the drop of the rear spring.
(A) 0-4" Drop Spring
(B) 5-7" Drop Spring
Part # 3GC-RR-100
Complete Mounting System----------$149.00
(with out shocks)
Part # 3GC-RR-101 Specify A or B
So Cal Shocks-----------$73.00/pair
(soft and smooth)
Part # 3GC-RR-102 Specify A or B
Doetch Hydrolic-------------$119.00/pair
(mild/med, good with air bags)
Part # 3GC-RR-103 Specify A or B
Doetch Nitro--------$139.00/pair
(Med/Firm, canyon carver)
Part # 3GC-RR-104 Specify A or B
Bilstien Invertia Valve---------$258.00/Pair
Smooth, self adjusts to conditions)
Part # 3GC-RR-105 Specify A or B
Romic Billit with adjustable rebound-----$269.00/pair
Great for performance tunning
Please give us a call @ No Limit 909-386-7637 or pm me with a private message if you are interested.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
