Old 11-06-2014, 04:11 PM   #1476
Hart_Rod
Hart_Rod's Avatar
Re: 68 S/C update.....
Originally Posted by skorpioskorpio View Post
Well I'm going to be using a mechanical throttle linkage and ITBs so basically, no 6L80 for me, because the 6Ls need torque management. The 6 speeded 4L80 though gives me a tight ratio 6 speed so I'm happy with that direction. You basically swap out the 1st and 2nd planetaries to slightly lower ratios and to make the gear combos make sense and then use a different valve body that can apply the OD clutch in 1st and 2nd as well as 3rd, so you get 1st, 1st+OD, 2nd, 2nd+OD, 3rd, and 3rd+OD. The valve body and TCM are from PCS.
Mine is going behind a 24 valve DOHC Trailblazer straight 6 with Weber DCOE pattern throttle bodies (though I may do actual DCOE Webers at first to get things going faster).
That sounds like a really sweet setup, .
Originally Posted by boostedc10 View Post
Damn Rob, everyone of your trucks are absolutely amazing! With the DD gauges, did you just order them black faced? Was there a cost difference? I like the way they look more stock.
Thanks Boosted. They are a custom setup I ordered from DD. It was more, but I can't remember how much. I'll have to check.
I ordered some new shocks from Ridetech today. I should have them by next week, .
Hart_Rod is offline   Reply With Quote
Old 11-06-2014, 04:19 PM   #1477
boynton
boynton's Avatar
Thanks so much for the info. I really appreciate the help.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 11-11-2014, 10:47 PM   #1478
Hart_Rod
Hart_Rod's Avatar
Your welcome! Glad I could help and let me know if you have any other questions.
My new Ridetech HQ shocks showed up today (ordered them Thursday). It took me a couple of hours to get them installed this evening. After installing them I took it for a short ride, and believe it or not, I could feel a difference as I was backing the truck down my driveway. I only took it on a short drive, but I'm already impressed with the difference in the feel of the truck. I'm going to drive it to work tomorrow and I'll give a better report, but so far, I give them a big thumbs up! OBTW, a BIG THANKS to board member Crawdadfox for getting my order shipped quickly, .
Old 11-11-2014, 10:56 PM   #1479
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Sweet!! Did you get the adjustable version?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 11-11-2014, 11:02 PM   #1480
Hart_Rod
Hart_Rod's Avatar
Yes sir!
Old 11-12-2014, 09:52 AM   #1481
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Thanks for the order Rob, give us an update when you get more seat time. Now go give Buck a hand getting that bed off!!
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 11-12-2014, 11:04 AM   #1482
C10_ustacould
That's what I'm talking about!!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 11-24-2014, 10:19 AM   #1483
mikentosh
mikentosh's Avatar
Love the build! Any updates on getting cruise working with the LS3?
mikentosh is offline   Reply With Quote
Old 11-24-2014, 11:07 AM   #1484
slowcpe
slowcpe's Avatar
So how are the new shocks treating you?
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 11-24-2014, 10:36 PM   #1485
Hart_Rod
Hart_Rod's Avatar
Thanks. I bought a Rostra module and with the help of a boardmember, made it work.
I really like them. I'm currently waiting on Moser to send me some new axles to replace the incorrectly machined ones that I originally purchased from them. The bad axles were causing a vibration that I have been chasing for a while now. Once I get them swapped out, I'll be doing some more road testing with the shocks, .
Old 11-25-2014, 09:40 AM   #1486
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Something like this?
http://www.summitracing.com/parts/rpc-250-2316
More details would be great if possible... I am about to work on this same thing...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 11-25-2014, 09:54 AM   #1487
Hart_Rod
Hart_Rod's Avatar
I'm not familiar with that kit. We used kit 1858, it's for a DBW. I'm sure there are other kits that will work (possibly 1848), but I'm not sure. The biggest hurdle we had was converting the 4K PPM o/p signal from the computer to an 128K PPM i/p signal that the 1858 was looking for. After that, the only other issue I had was with LED tail lights.
Old 11-25-2014, 11:06 AM   #1488
chevyguy_72
Vintage Evil
Resistance issues or something to that effect?
Current Rides:
Old 11-27-2014, 11:05 AM   #1489
Hart_Rod
Hart_Rod's Avatar
Yes. The lights worked great without a resistor, but there wasn't enough resistance to allow the CC to "latch". When I put a factory bulb back in, the CC worked fine. I just need to add a relay to the CKT and then I can put the LED tail lights back in.
Old 11-27-2014, 03:07 PM   #1490
WiggyHD
My new Ridetech HQ shocks showed up today OBTW, a BIG THANKS to board member Crawdadfox for getting my order shipped quickly, .
Were they Part #: 22189841 (rear) and Part #: 22149841 (front)? I didn't see anything pertaining to a different part number for a lowered truck.
Thanks!
Mark
Retired Air Force/Disabled Vet
1969 Chevy C-10, On the way to greatness!
WiggyHD is offline   Reply With Quote
Old 11-27-2014, 06:03 PM   #1491
Hart_Rod
Hart_Rod's Avatar
Thanks!
Mark
Mark - measured the difference between mounting points on my front and rear shocks and then called Ridetech. They recommend the shock number that I should buy base off of those measurements.
On a different note, I changed out the axles hoping that the rear vibration/hop would go away but it didn't.... So I got to looking at the rotor/axle hub where the rear wheel bolts on and you can see where the wheel isn't bolting on centered. I think the CPP rotor is so thick that very little of the hub area is sticking out past the rotor, so the wheel is not centering up on the wheel flange. I have the cone style lugnuts but they are not forcing the wheel to center up, which is causing the rear to bounce. . Not really sure what to do now....
Old 11-28-2014, 10:11 AM   #1492
chevyguy_72
Vintage Evil
I actually read an post somewhere that said one of the axle tubes had tweaked under load and caused this same symptoms... This was a 1000hp truck... but who knows what it would actually take to tweak one...
Just a thought... I will see if I can find the post...
Current Rides:
Old 11-28-2014, 10:29 AM   #1493
Hart_Rod
Hart_Rod's Avatar
I don't believe it's an axle tube. This problem started when I rebuilt the rearend and added the rear CPP disc brakes. I had these wheels on with drum brakes and had no such problem. I'm pretty sure it's due to the fact that the wheels aren't centering up on the hub when I bolt them on. I'm going to pull a rotor off and bolt the wheel on and see if I still have the same problem.
Old 11-28-2014, 11:01 AM   #1494
chevyguy_72
Vintage Evil
Yeah I could see that being an issue as well...
Current Rides:
Old 11-29-2014, 01:01 PM   #1495
class01
class01's Avatar
Did you use front shock relocators?
class01 is offline   Reply With Quote
Old 12-01-2014, 01:53 PM   #1496
Hart_Rod
Hart_Rod's Avatar
Yes and I purchased Ridetech shocks made to fit the ride height of the truck.
Old 12-13-2014, 12:32 PM   #1497
Hart_Rod
Hart_Rod's Avatar
Haven't done much to the 68 lately, I've been sick since Thanksgiving. I did develop/fabricate a bolt in pedal mounting bracket for the GEN III DBW gas pedals. Here's a link and a few pics. Let me know if you are interested in one.
http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Old 12-14-2014, 01:00 PM   #1498
Chvy2NV
Looks good! Which are the correct year/ model pedals for both brackets. I have your first design.
Chvy2NV is offline   Reply With Quote
Old 12-14-2014, 01:02 PM   #1499
Hart_Rod
Hart_Rod's Avatar
The one you have is for a Gen IV motor using the 05+ Corvette pedal. The new one is for a Gen III motor using the truck/suv DBW pedal.
Old 12-14-2014, 02:06 PM   #1500
jaros44sr
jaros44sr's Avatar
Sorry your not feeling for an extended time Rob, hopefully it will pass soon. I remember one christmas season where the whole family was sick on christmas weekend, miserable.
Great build, enjoy reading.....that rear end is a strange one, wish i had a suggestion to help. Very curious to find out the fix, as i m sure you are as well
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
