Re: 1959 Chevy Truck
Looking real nice.
Kim |
Wires
USCG Aviator C-130 1959 Stepside build - http://67-72chevytrucks.com/vboard/s...d.php?t=602386 |
Fuse
Side
Dakota digital
Front
Side 2
Back
Engine pic
Engine 2
I got the exact same seat but mine is around my kitchen table! LOL!
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#12 | |
I'm at a tuff spot, I thought it would be fairly easy fabricating the front part of the radiator and bumper mount.... I think I'm just tired of fabricating right now because I feel so overwhelmed by getting it welded up and square and not having the front end crooked. And I think I might have moved the wheel a bit to far forward. But no changing that now.
#13 | |
![]() Join Date: Jan 2014
Great work, your front wheel looks centered to me, on my truck I bolted the front clip on just using the top and bottom bolts on the rear of the fenders, mounted the inner fenders and bolted them to the rad support, I then lifted the whole front clip off and on as one piece while I was test fitting it and getting the rad support mounts in the right place and trimming the inner fenders.
Here's a shot of my 59 at about the same angle to show you the wheel placement. ![]() Quote:
1959 fleetside 1955 Chevy LCF 5400 Wrecker 1958 Chevy Viking 1956 Chevy LCF 5400 74 Jimmy D60 14bolt 94 crewcab SAS cummins Last edited by bigtim44; 03-11-2014 at 09:50 PM. |
#14 | |
#15 |
Front
#16 |
You're doing a real nice job on it.
Kim |
#17 |
59Stepside, are you anywhere near the Harland Check printer plant? I've been to Tampa quite a few times at that plant. I guess now it's called Harland Clarke. The Tampa guy's used to call me "Oh Canada". Treated me to the "Cabaret". Follow me? LOL! I think your 59 will end up being the same as my 51. After many and I mean many beer, there's going to be enough shimming room to adjust your front end. I was out pondering and sipping and figure it's only beer and welding wire. Both can be restocked.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() Last edited by FarmerSid; 03-11-2014 at 09:18 PM. |
#18 | |
#19 |
Looking real nice.
That pic of the kids looks cool (old time vibe to it). Nice rims. Kim |
#20 |
I like the stance,get them radiator support mounts finished and you'll be cruising. If the bottom hose outlet on the radiator hits the anti roll bar ,just slide the radiator up a wee bit and drill some new mounting holes in the rad support.
#21 |
Thx Kim and bigtim,
Crazy thing is, I went just a little more forward with the wheelbase so the rad support mount was right on the steering box. I cut everything around it so it would clear the steering box. So ended up loosing the original mounting spots on bottom of support. I did some fabricating and got it on there. I decided to move the radiator in front of the support and that created a lot of extra cutting and fitting to get it right. I think it looks pretty sweet with it so close to the grill, but now I need to figure out a different way to latch the hood. --anyone ever have an issue with the rear of the hood sitting up real high when closed. But can push it down with hand. It was like that before. But it's even worse now.
USCG Aviator C-130 1959 Stepside build - http://67-72chevytrucks.com/vboard/s...d.php?t=602386 Last edited by 59stepside; 04-19-2014 at 09:51 AM. |
#22 |
Rims and tires are on. Ordered the cool ride airbag kit because with the 2" drop spindles this thing is pretty much on the ground. I have an inch or so from bottom of headers and tranny pan.
And I will drop the rear when time and money permits, but goal is to get it drivable right now...
#23 |
That's going to be real low.
Kim |
#24 |
Yeah, to low to drive it... I'm hope that I can get it high enough with the airbags to have a decent height to get around town w speed bumps and driveways.
#25 |
stock spindles will get your static ride height correct and level out the truck
they will also safe you the cost of bagging it do you plan on c-notching the rear? you will spend lots of time clunking the frame if not. with stock springs plan on a minimum 4'' notch, 5'' would be better i used a 3'' notch and had to use air shocks to keep off my bump stops
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
