Old 08-28-2024, 03:24 PM   #1
pjmoreland
pjmoreland's Avatar
1971 K10 Stepside - Getting a Roller Roadworthy
I've been looking for a 115" wheelbase K10 at a reasonable price and in need of rehabilitation for a while now. I bought this one locally from a woman who owns a body shop. It appears to me that she and her husband were buying and restoring classic trucks as part of their business. Sadly, her husband, who was young, passed away recently, so she is selling off some vehicles. I hauled it home a few days ago.
The truck is stripped down pretty far. It has no engine, transmission, transfer case or driveshafts. The body, however, appears to have no rust holes anywhere, and that's the main reason I decided to go for it. A Chevy Truck Red Book I've got says there were 1438 of these short wheelbase stepside K10s build in 1971, so it's definitely worth keeping.
My initial plan is to focus just on getting it roadworthy. I'm also going to undo the crazy high lift it's got right now. It's got a 4" body lift, and the leaf brackets have been welded to the frame with sections of box tubing between them and the frame. I will be grinding all of that off so that the brackets can be reinstalled in their original locations.
My plan is to find an NV4500 transmission and an NP205 transfer case. I've got a used l31 Vortec 350 that's in decent condition that I'm going to throw in it. The one bummer is that I'll have to install an electric fuel pump since the l31 block isn't machined for a mechanical pump.
It's going to be a bit slow going at first because I have some other projects I need to finish up. The transmission is removed from my '68 stepside right now, and I'm going to be rebuilding the 4L60 transmission in my '89 over the next couple of weeks.
I ordered a windshield yesterday so that I can get the cab sealed up before the rain comes.
Table of Contents
Windshield Installation #33 https://67-72chevytrucks.com/vboard/...7&postcount=33
Old Rear Bumper Removal #54 https://67-72chevytrucks.com/vboard/...2&postcount=54
Rear Leaf Spring Perch Restoration #71 https://67-72chevytrucks.com/vboard/...5&postcount=71
Front Leaf Spring Perch Restoration #76 https://67-72chevytrucks.com/vboard/...4&postcount=76
Radiator Support Replacement #92 https://67-72chevytrucks.com/vboard/...5&postcount=92
Clutch Rod Firewall Hole Repair #98 https://67-72chevytrucks.com/vboard/...7&postcount=98
Frame Crack Repair #103 https://67-72chevytrucks.com/vboard/...&postcount=103
Steering Column Rebuild #104 https://67-72chevytrucks.com/vboard/...&postcount=104
Drag Link Rebuild #108 https://67-72chevytrucks.com/vboard/...&postcount=108
Fuel Tank Clean, Reinstallation #118 https://67-72chevytrucks.com/vboard/...&postcount=118
Rear Axle Rebuild #126 https://67-72chevytrucks.com/vboard/...&postcount=126
Front Axle U-Joint Replacement #146 https://67-72chevytrucks.com/vboard/...&postcount=146
Front Axle Rebuild #148 https://67-72chevytrucks.com/vboard/...&postcount=148
Rear Axle Reinstallation #163 https://67-72chevytrucks.com/vboard/...&postcount=163
Front Diff Rebuild #172 https://67-72chevytrucks.com/vboard/...&postcount=172
Rear Brakes #193 https://67-72chevytrucks.com/vboard/...&postcount=193
Front Hub Rebuild Attempt #205 https://67-72chevytrucks.com/vboard/...&postcount=205
Inner Fender Rust Repair #215 https://67-72chevytrucks.com/vboard/...&postcount=215
Battery Tray Rebuild #226 https://67-72chevytrucks.com/vboard/...&postcount=226
Tail Light Rebuild #230 https://67-72chevytrucks.com/vboard/...&postcount=230
Driver Door Speaker Hole Repair #238 https://67-72chevytrucks.com/vboard/...&postcount=238
Front Hub Rebuild Attempt 2 #258 https://67-72chevytrucks.com/vboard/...&postcount=258
Passenger Door Speaker Hole Repair #260 https://67-72chevytrucks.com/vboard/...&postcount=260
Passenger Rocker Panel Replacement #269 https://67-72chevytrucks.com/vboard/...&postcount=269
Driver Rocker Panel Replacement #286 https://67-72chevytrucks.com/vboard/...&postcount=286
Frunt Hub Final Rebuild #293 https://67-72chevytrucks.com/vboard/...&postcount=293
Dash Patch & Rust Repair #294 https://67-72chevytrucks.com/vboard/...&postcount=294
Rear Window Replacement #317 https://67-72chevytrucks.com/vboard/...&postcount=317
Clutch Rod Repair #334 https://67-72chevytrucks.com/vboard/...&postcount=334
Cab Support Rust Repair #344 https://67-72chevytrucks.com/vboard/...&postcount=344
Cab Floor Undercoating #345 https://67-72chevytrucks.com/vboard/...&postcount=345
Frame Rail Paint #348 https://67-72chevytrucks.com/vboard/...&postcount=348
Front Brake Calipers #351 https://67-72chevytrucks.com/vboard/...&postcount=351
Brake Lines & Hoses #358 https://67-72chevytrucks.com/vboard/...&postcount=358
Clutch Pedal Install #361 https://67-72chevytrucks.com/vboard/...&postcount=361
Brake Booster & MC #362 https://67-72chevytrucks.com/vboard/...&postcount=362
Brake Pedal Rod Modification #368 https://67-72chevytrucks.com/vboard/...&postcount=368
Parking Brake Front Cable #369 https://67-72chevytrucks.com/vboard/...&postcount=369
Engine Mount Repair #380 https://67-72chevytrucks.com/vboard/...&postcount=380
Parking Brake Intermediate Cable #381 https://67-72chevytrucks.com/vboard/...&postcount=381
Dash & Floor Paint #394 https://67-72chevytrucks.com/vboard/...&postcount=394
Clutch Safety Switch Bracket #400 https://67-72chevytrucks.com/vboard/...&postcount=400
New Shocks #401 https://67-72chevytrucks.com/vboard/...&postcount=401
Steering Box Brace #402 https://67-72chevytrucks.com/vboard/...&postcount=402
Fuel Lines #417 https://67-72chevytrucks.com/vboard/...&postcount=417
Firewall Insulation #423 https://67-72chevytrucks.com/vboard/...&postcount=423
Dash Pad #424 https://67-72chevytrucks.com/vboard/...&postcount=424
Heater Controls Rebuild #432 https://67-72chevytrucks.com/vboard/...&postcount=432
Wiper Motor Install #434 https://67-72chevytrucks.com/vboard/...&postcount=434
Heater Box Install #435 https://67-72chevytrucks.com/vboard/...&postcount=435
Transfer Case Input Shaft #440 https://67-72chevytrucks.com/vboard/...&postcount=440
Radio Install #454 https://67-72chevytrucks.com/vboard/...&postcount=454
Transmission Tail Housing Machining #456 https://67-72chevytrucks.com/vboard/...&postcount=456
Transmission Tail Shaft Replacement #459 https://67-72chevytrucks.com/vboard/...&postcount=459
Fresh Air Door Rebuild #485 https://67-72chevytrucks.com/vboard/...&postcount=485
Bed Wood Dimensional Drawing #495 https://67-72chevytrucks.com/vboard/...&postcount=495
Tach Rebuild #498 https://67-72chevytrucks.com/vboard/...&postcount=498
Bed Wood Cutting #502 https://67-72chevytrucks.com/vboard/...&postcount=502
Transmission Reassembly #518 https://67-72chevytrucks.com/vboard/...&postcount=518
Tach Rebuild Finished #526 https://67-72chevytrucks.com/vboard/...&postcount=526
Transfer Case Shifter Mount Design #527 https://67-72chevytrucks.com/vboard/...&postcount=527
Engine Refresh #532 https://67-72chevytrucks.com/vboard/...&postcount=532
Transfer Case Shifter Mount Fabrication #534 https://67-72chevytrucks.com/vboard/...&postcount=534
Transmission Shifter Slop Repair #541 https://67-72chevytrucks.com/vboard/...&postcount=541
Rear Main Seal #548 https://67-72chevytrucks.com/vboard/...&postcount=548
Engine Install #550 https://67-72chevytrucks.com/vboard/...&postcount=550
Transmission Crossmember NV4500 Adapter Fabrication #557 https://67-72chevytrucks.com/vboard/...&postcount=557
Lockset Installation #571 https://67-72chevytrucks.com/vboard/...&postcount=571
Driveshafts #590 https://67-72chevytrucks.com/vboard/...&postcount=590
Transmission Hump Modification #593 https://67-72chevytrucks.com/vboard/...&postcount=593
Exhaust Manifolds, Spark Plug Shields #600 https://67-72chevytrucks.com/vboard/...&postcount=600
Bellcrank Engine Mount #601 https://67-72chevytrucks.com/vboard/...&postcount=601
Transmission Hump Modification Complete #602 https://67-72chevytrucks.com/vboard/...&postcount=602
Clutch Linkage #612 https://67-72chevytrucks.com/vboard/...&postcount=612
Power Steering Pump Bracket Repair #622 https://67-72chevytrucks.com/vboard/...&postcount=622
Alternator Bracket Repair #623 https://67-72chevytrucks.com/vboard/...&postcount=623
Steering Box Frame Brace Repair #624 https://67-72chevytrucks.com/vboard/...&postcount=624
Transmission Hump Install #635 https://67-72chevytrucks.com/vboard/...&postcount=635
Power Steering Pump & Alternator Install #636 https://67-72chevytrucks.com/vboard/...&postcount=636
Distributor Rebuild #637 https://67-72chevytrucks.com/vboard/...&postcount=637
Grille Install #643 https://67-72chevytrucks.com/vboard/...&postcount=643
Front Bumper Install #657 https://67-72chevytrucks.com/vboard/...&postcount=657
Battery Tray, Charcoal Canister Install #660 https://67-72chevytrucks.com/vboard/...&postcount=660
Spark Plug Wires #665 https://67-72chevytrucks.com/vboard/...&postcount=665
Inner Fenders #668 https://67-72chevytrucks.com/vboard/...&postcount=668
Fuel Pump #674 https://67-72chevytrucks.com/vboard/...&postcount=674
Wiring #679 https://67-72chevytrucks.com/vboard/...&postcount=679
Gauge Cluster #732 https://67-72chevytrucks.com/vboard/...&postcount=732
Charcoal Canister Hoses #751 https://67-72chevytrucks.com/vboard/...&postcount=751
First Startup #758 https://67-72chevytrucks.com/vboard/...&postcount=758
First Move Under Own Power #765 https://67-72chevytrucks.com/vboard/...&postcount=765
Coolant Overflow #768 https://67-72chevytrucks.com/vboard/...&postcount=768
Windshield Washer #769 https://67-72chevytrucks.com/vboard/...&postcount=769
Cowl Screen #770 https://67-72chevytrucks.com/vboard/...&postcount=770
First Drive #785 https://67-72chevytrucks.com/vboard/...&postcount=785
Carpet #794 https://67-72chevytrucks.com/vboard/...&postcount=794
Mirrors, Antenna #798 https://67-72chevytrucks.com/vboard/...&postcount=798
Rear Bumper #799 https://67-72chevytrucks.com/vboard/...&postcount=799
Speedometer Cable #800 https://67-72chevytrucks.com/vboard/...&postcount=800
Exhaust #812 https://67-72chevytrucks.com/vboard/...&postcount=812
New Power Steering Pump #817 https://67-72chevytrucks.com/vboard/...&postcount=817
Starter Brushes, Solenoid #821 https://67-72chevytrucks.com/vboard/...&postcount=821
Bed Wood Tung Oil #825 https://67-72chevytrucks.com/vboard/...&postcount=825
Old Bed Wood Removal #829 https://67-72chevytrucks.com/vboard/...&postcount=829
Bed Angle Strip Repair #834 https://67-72chevytrucks.com/vboard/...&postcount=834
NV4500 Shifter Stub Straightening #838 https://67-72chevytrucks.com/vboard/...&postcount=838
Transmission Removal #850 https://67-72chevytrucks.com/vboard/...&postcount=850
Transmission Synchros Replacement #863 https://67-72chevytrucks.com/vboard/...&postcount=863
Transmission Test Drive #879 https://67-72chevytrucks.com/vboard/...&postcount=879
Valve Seals Replacement #885 https://67-72chevytrucks.com/vboard/...&postcount=885
Throttle Cable Shortening #890 https://67-72chevytrucks.com/vboard/...&postcount=890
Dual Horns #892 https://67-72chevytrucks.com/vboard/...&postcount=892
Bed Wood Install #902 https://67-72chevytrucks.com/vboard/...&postcount=902
Leaf Spring Bushing Replacement #912 https://67-72chevytrucks.com/vboard/...&postcount=912
Driver Door Interior Dent Repair #928 https://67-72chevytrucks.com/vboard/...&postcount=928
Tie Rod End Replacement, Steering Stabilizer #940 https://67-72chevytrucks.com/vboard/...&postcount=940
Passenger Door Rebuild #984 https://67-72chevytrucks.com/vboard/...&postcount=984
Driver Door Rebuild #992 https://67-72chevytrucks.com/vboard/...&postcount=992
Steering Arm Replacement #1002 https://67-72chevytrucks.com/vboard/...postcount=1002
Vent Window Rebuild #1022 https://67-72chevytrucks.com/vboard/...postcount=1022
Pitman Arm Replacement #1031 https://67-72chevytrucks.com/vboard/...postcount=1031
Door Reassembly #1040 https://67-72chevytrucks.com/vboard/...postcount=1040
Shock Upgrade #1045 https://67-72chevytrucks.com/vboard/...postcount=1045
Seat Tear Down #1057 https://67-72chevytrucks.com/vboard/...postcount=1057
Hitch Receiver #1068 https://67-72chevytrucks.com/vboard/...postcount=1068
Side Mounted Spare Tire Fender Prep #1076 https://67-72chevytrucks.com/vboard/...postcount=1076
Seat Upholstery #1078 https://67-72chevytrucks.com/vboard/...postcount=1078
Side Mounted Spair Tire Carrier #1091 https://67-72chevytrucks.com/vboard/...postcount=1091
Dome Light Door Switches #1125 https://67-72chevytrucks.com/vboard/...postcount=1125
Spare Tire Installed #1130 https://67-72chevytrucks.com/vboard/...postcount=1130
Tow Hooks #1142 https://67-72chevytrucks.com/vboard/...postcount=1142
Tall Front Bump Stops #1152 https://67-72chevytrucks.com/vboard/...postcount=1152
Carb Offroad Mods #1155 https://67-72chevytrucks.com/vboard/...postcount=1155
Cruise Control #1161 https://67-72chevytrucks.com/vboard/...postcount=1161
Road Trip to Moab #1169 https://67-72chevytrucks.com/vboard/...postcount=1169
Speedometer Gear Seal #1190 https://67-72chevytrucks.com/vboard/...postcount=1190
Carter Fuel Pump #1194 https://67-72chevytrucks.com/vboard/...postcount=1194
Hickey-style Skid Plate #1195 https://67-72chevytrucks.com/vboard/...postcount=1195
Trailer Hookup #1197 https://67-72chevytrucks.com/vboard/...postcount=1197
Door Hinge Friction Pads #1198 https://67-72chevytrucks.com/vboard/...postcount=1198
HEI Weight Bushings #1203 https://67-72chevytrucks.com/vboard/...postcount=1203
Vacuum Advance Stop #1207 https://67-72chevytrucks.com/vboard/...postcount=1207
Under Bed Fuel Tank #1212 https://67-72chevytrucks.com/vboard/...postcount=1212
Vintage Air A/C #1257 https://67-72chevytrucks.com/vboard/...postcount=1257
pjmoreland is offline   Reply With Quote
